crazy bots series 1 (the remake)
  • Re: crazy bots series 1 (the remake)
    And that's why I should've entered Extreme Gyration...
      oops i did take it a bit too far
        No no, an 800kj spinner can do that to robots sometimes...
        Just look at MDU in PTT3. It obliterated half of its opponents...
          Yep. Now it's a lethal translational spinner that's gathering dust in Aaron's virtual shed.
          I expect several of my vapourbots will also hit the virtual shed once I start working on Flamberge and Altitude... :P
            lian: let heat c begin
            pod 1:
            hexyD (kody)
            iron awe 6 (jack)
            pod 2
            st hammer
            king b
            3 2 1 ACTIVATE
            hexyd comes right out off the traps and flings king buxton into the air (6 ft to be precise) and it lands next to the flame
            pit, meanwhile iron awe pushes st hammer towards the ppz and flips it into the air and back down, now hexyd flips kingb
            into orbit again and again and again, but has lost intrest and goes after iron awe and flips them on their back but
            iron awe quickly self rights but is flipped again by hexyd now king b pushes st hammer into the pit release and dumps
            st hammer in now king b rams in on hexyd but hexyd flips them into the cpz where shunt is waiting and slams the axe
            through king b as iron awe flips hexyd on his back but quickly self rights and flips iron awe in turn now turns its attention
            to king b who gets flipped sky high by hexyd, as iron awe flips king b onto the flame pit, but king b is not moving in
            comes the refbot to count them out, 1 2 3 4 5 6 7 8 9 10, now iron awe flips hexyd but hexyd self rights and tosses
            iron awe across the arena and out, now shunt puts more holes in king b as mr pshyco pounds away at whats left poor
            old king b
            CEASE
              pod 1:
              hexyD (kody)
              iron awe 6 (jack)
              pod 2
              st hammer
              king b
              3 2 1 ACTIVATE
              old king b
              CEASE
                lian: we are back
                pod 1
                frp/liam
                arc smacker/mark
                pod 2:
                kan opener
                loki/lewis
                3 2 1 activate
                loki gets those hammers up to speed and hits at kan opener and hits it hard now arc smacker hits kan opener now frp
                whacks arc smacker and its spun across the arena floor but arc comes back and hits kan opener but kan opener grabs
                arc and pushes it against the pit release and tries to put arc in the pit but is having its front torn up but still bravely
                tries to push back as loki and final resting place smack each other silly now loki hits in on on arc smacker and it
                bounces up in the air giving kan opener the boost needed to pit it, boom there goes the smoke there out as loki now
                smashes into kan opener who has now lost drive on one side now final resting places shatters the top armour of the
                kan opener and is pushed into the ppz where shunt put its axe through the safety link and now kan opener is being
                counted out by the refbot 1 2 3 4 5 6 7 8 9 10
                CEASE sorry it was short
                  2nd round draws
                  final resting place vs hexyd
                  iron awe 6 vs loki
                    if i remember correctly loki has some spinning hammers, so flip it from the sides like there is no tomorow. try and get it out the arena
                    good luck guys
                      Tactics: flip.
                        lian walsh: *dusts off the cobwebs on trenchcoat which is red * welcome back and ive been chewing marbles for like
                        10 days so lets get on with it max green how the feelin
                        max: thanks lian, so kody how do you feel about this battle with final resting place
                        kody: not really bothered since the spinning ring is in the middle and its ground clearance is pretty high with the disc on
                        so stack the bugger
                        max: you really are confident all the time arent you
                        kody: yes, yes i am
                        max: wheres liam
                        liam: under these flippin cobwebs *bursts free*
                        max: your up against hexy D
                        liam: oh CRAP
                        max: what are your tactics
                        liam: spin, thats all i can do
                        max: get in there mate
                        lian walsh: LET THE WAAAAAAAAAAAAAAAAARS BEGIN!!!!!!!!!!!!!!!
                        pod one: kody/hexy
                        pod two: liam/frp
                        with a new intro
                        THE BOX IS LOCKED THE LIGHTS ARE ON ITS CRAZY BOT FIGHTIN TIME!!!!!! and the battle is in new font as welll
                        hexy races out of the traps and flips final resting place over and now flips it against the side
                        wall and goes to flip it out but only flips it back into mobillity again :shock: but it aint away from hexy who flips
                        again into shunt who powerslams frp with its axe BANG BANG, BANG BANG 4 holes on the top of the bot who
                        turns for safety to get itself up to speed but it cant as hexy is all over it like fly on manure
                        now hexy flips it into the pit release button as dead metal comes in and tries to cut into hexy but not even a
                        scratch is left on hexy who flips frp over again and it appears to have stopped moving oh dear liam your frp is
                        out, as the countdown begins 1 2 3 4 5 6 7 8 9 10 but hexy is being chased by mr phsyco and sir killalot
                        but it pushes sir killalot into the pit CEASE
                        coming up next loki vs iron awe 6
                          major rule change: since i aint had time for this series it will only be 6 heats long
                          as the crazy bot games start next month
                            we return at heat c (1st 2 battles of heat d tommorrow along with the x-mas finals )
                            loki vs iron awe 6
                            3.2.1 ACTIVATE
                            loki gets off to a flying start spinning and hits ia6 in the side and sends it flying across the arena, but ia6 comes back
                            and flips loki on its backon the flame pit and lokis self righting bar is jammed in there and ia6 seems to be waiting for
                            them to self right but they cant as dead metal comes in the with the saw BZZZZZZZZZZZZZZZZZAT!!!!!!!! and not
                            even dead metal can get it off but ia6 flips them against the side wall and flips them up but they are balancing on the
                            brink of destruction now mr psycho picks up ia6 and spins it around and around and around and finally drops them as
                            shunt comes after ia6 but flips it over and now it flips loki oota CEASE
                            heat final
                            hexyD vs ia6
                            3 2 1 activate
                            ia6 the 1st to move and flips hexyD on its back but they self right and proceed to flip ia6 over again and again and they
                            push ia6 into the house robots and growler picks them up and slams them into the wall now hexy hits the pit release
                            as ia6 tries to fight its way out of growlers mouth but to now avail but hexy d comes in and flips them both over but
                            growler wont let go of ia6 now hexy d luanches growler into the air and against the wall and it finally lets go of ia6 who
                            gets under hexy d and launches them 8ft into the air and into the pit CEASE WHAT AND UPSET
                            heat e and f draws in a few mins
                            sorry they where short :|
                              mark due to dr acula retiring please choose a replacement
                                Lian, when I retire a robot after I enter it into a competition, it simply means that this'll be its last tourney. Besides, Dr. Acula hasn't fought in a year, so let's see how it fights!!!
