crazy bots series 1 (the remake)
  • #76
    Re: crazy bots series 1 (the remake)
    By the battle saying that 4 legs were on the ground, it seems to me that Anarchy wasn't pushed into the pit, just over the edge
    As for the heat final, shouldn't be too difficult. I'm to manouevrable for it to really catch me, and one flip should finish it.
    Good luck Kody
    also a big improvement to the layout of the battles Lian, makes them a lot easier to read
    • #77
      Originally posted by death robotics
      ok you 2 stop you can settle this with a grudge match in heat b
      Weren't arguing, just having a little debate. No grudge.
      • #78
        Okay, we'll settle it later.
        • #79
          minesweeper and oid are in the final 10 bot rumble
          • #80
            *Raises Eyebrow* What 10-bot rumble?
            • #81
              at the end of a series there will be a ten bot brawl minesweep3r and oid are in that rumble
              • #82
                Lian walsh: welcome back to crazy bots
                let the heat final begin
                pod 1: kody kunz/anarchy
                pod 2: liam/apocolypse
                3!!!!!! 2!!!! 1!!!!! ACTIVATE!!!!!!
                here we go with our 1st heat final
                anarchy scuttles across with pace at apocolypse and down comes the axe WHACK it catches in apocolypse
                but it flips the axe away and goes round the back and flips BANG!!! anarchy is on his back and is trying to self right
                apocolypse comes in and takes it to the side wall and flips but anarchy lands back on its feet to continue
                from the control pod kody sighs with relief and now anarchy land repeated axe blows like a lumberjack
                who now pushes apocolypse to the cpz with mr pshyco but the hammer of pshyco misses apocolypse and hit anarchy
                BANG!!!! but anarchy comes out unscathed, now apocolypse goes round the back of anarchy and flips but what quick
                reactions but kody who fires the axe to pop it back on its wheels or should i say legs now anarchy is
                rammed into the ppz where matilda is lurking with a fully spinning flywheel BZZZZZZZT! of comes a side panel but anarchy gets away to fight another day, but for how longer as apocolypse flips anarchy who does a 360 spin
                in the air and lands back on its feet in the control pod liam is loving this but kody looks worried as apocolypse comes
                in again and flips but not over and again and again now charges anarchy into the pit release BANG!!!!!! there goes
                the siren down goes the pit and now anarchy almost has apcolypse in the pit, but it burns rubber to survive, WHOA!!!
                look at the scorch marks that came from those tires, now anarchy is flipped again but this time lands on its back
                now apocolypse leaves it be as the countdown begins 1 2 3 4 5 6 7 8 9 10 oh and here come the house robots
                to pound away but apocolypse flips matilda over and bravely goes after mr pshyco and FLIPS HIM ON HIS BACK
                now he flips the refbot oota lol
                CEASE is called but to show theres no hard feelings apocolypse self rights anarchy
                next heat and draws to come
                • #83
                  2nd heat draws
                  panic attack vs brutalis (liam/swimm3r) vs crooked evo (jack) vs mute
                  raven the 4th (kody) vs mega roll 2 (mark) vs storm2 vs firestorm V
                  tatics predictions and my head stone please
                  • #84
                    *Places stone on Lian's head* There's your headstone.
                    Panic Attack and Crooked Evo out.
                    Kody, how about we team up on the 2 realies? Let him kill Storm II, while I use my drum to wreck Firestorm's aluminum.
                    • #85
                      heat c and d draws
                      heat c
                      hexadecimtor (kody) vs iron awe 6 (jack) vs king b vs st hammer
                      kan opener vs arc amacker (mark) vs loki (lewis) vs final resting place (liam)
                      heat d
                      smidsy (kody) vs lock jaw v3 (liam) vs dr acula (mark) vs killer b
                      diotor (kody) vs big nipper vs mortis vs dantomkia (jack)
                      more tactics predictions
                      • #86
                        kan opener vs arc smacker (mark) vs loki (lewis) vs final resting place (liam)
                        Spinning rim vs 2 discs vs spinning blade vs crunching jaws. I'll quickly turn on the Melty Brain system and spin up both the discs and the robot. Then I'll run in and hit Loki, run away, and hit Kan Opener. Then I'll repeat over and over until they stop moving. If you want, Liam, we can team up.
                        smidsy (kody) vs lockjaw v3 (liam) vs dr. acula (mark) vs killer b
                        I don't know what Killer B is, so I'll leave it for the next round. Get around to the back of Lockjaw, crunch down with the jaws, and pit him. Do the same to SMIDSY.
                        • #87
                          killer b is a battle bot rammer that hit a wall so hard it shook the entire battlebox
                          • #88
                            I think it's this: http://www.mcmanis.com/chuck/robotics/killerB.html
                            • #89
                              yep thats the one
                              • #90
                                Panic Attack vs Brutalis 2.1 vs CrOoKeD eVo vs Mute
                                The realies to bite it. :P
                                Raven the 4th vs Mega Roll 2 vs Storm II vs Firestorm V
                                Aw hell, just go after whatever's closest. Nothing will last too long against my weaponry.
                                Hexadecimator vs Iron Awe 6 vs King B Powerworks vs St. Hammer
                                Note that this is the version of Hexy-D that competed in the 2006 Robogames. Better armoured, better flippability, better drive, better everything, really. :P Anyway go after all of them, flip them a lot, self-right when needed.
                                Kan-Opener vs ARC Smacker vs Loki vs Final Resting Place
                                Liam and Lewis through.
                                S.M.I.D.S.Y. vs LockJaw v3 vs Dr. Acula vs KillerB
                                KillerB I know, the others I really don't, so lift things, smash things, and generally have fun.
                                Diotoir vs Big Nipper vs Mortis vs DanTomKia
                                Hmm...I may actually have a chance here! Go after Big Nipper's sides and keep flipping it or push it into the pit, while DTK takes care of Mortis.
