Velociraptor's Fanfic Tournament: The Comeback
  • #61
    Velociraptors Fanfic Tournament: The Comeback
    http://www.youtube.com/watch?v=WXT8-oAG8NMhttp://www.youtube.com/watch?v=WXT8-oAG8NM
    Its not that slow actually.
    • #62
      Thanks, guys! So heres the draw for Round 1 of...um...lets call it VFT 7.5:
      Flaming Hell vs SOR X
      Robo-Owl vs Squish Reincarnated
      Psyclonizer vs Under Pressure
      Walk Dont Run 3 and a Half vs Wedge Devolution
      Reventon vs STAT
      Eurypterus Evolved vs The 6isc
      Achilles vs Leprosy Infection
      Exodus vs Holepunch
      Flipping Hell vs Wedginator Devilution
      Spin Dash Unleashed vs Troubloon 6
      Nidhogg vs The May Tracks Has You
      Back To Rock 3 vs Flank Attack 2
      Inferno vs Sacrifice
      Axe-O-Lotl vs System Shock 4.0
      Eternia vs Nitrogene 5.0
      Black Panther vs Robo-Hedgehog
      • #63
        TACTICS OF A WOOTY NATURE AS BEFITS A WOOTY TOURNAMENT:
        STAT vs. Reventon
        Firstly, his blade wont be able to do much to me, seeing as it appears to be on a straight 1:1 reduction from the motor if the speed given (6000rpm) is anything to go by, so I think torque for damaging anything will be limited and my foam rubber tyres are rather safe...basically, just get in there with speed, power, power, power, power, and speed, ram it around, be all over it like an overexcited puppy and never let it get time to recover, possibly sticking the spike in through any gaps or the slot in front for the blade. The ground clearance I have should minimalise the chances of him being able to push me around since the wheels should still have traction, so go all out until I get the chance to get it down the pit, at which point I aim to get it in as quickly as possible while also being controlled enough in my movements to avoid falling down myself.
        NIDHOGG vs. The May Tracks Has You
        Get in at the side, lift, crush, pit button, pit, avoid flipper and arena walls.
        Good luck people
        • #64
          TACTICS AND UBER-PREDICTIONS:
          (Winners in Italics, my robots in Bold)
          Reventon vs STAT
          Exodus vs Holepunch
          Robo-Owl vs Squish Reincarnated: Attack Robo-Owl at the sides and aim to get it onto the wedge. Crush down and hope to disable one half of the tracks, or drag the machine towards the pit. Avoid the blade and mainly focus on attacking the tracks.
          Inferno vs Sacrifice: According to the stats, Inferno is using two small (compared to some) drive motors that draw a lot of amps, meaning that it produces a lot of heat. Also, it seems that Inferno is protected inside by flammable foam. Personally I think Inferno is quite an apt name for Pauls machine. Burn, Robot, Buuuurrrn!
          • #65
            Squish Reincarnated vs Robo-Owl: Get round the back and sides, maybe try to rip the srimech off, shred the armour, use the arena disc or pit
            Black Panther vs Robo-Hedgehog: Use the scoop setup, manouvre round the back, push into the hazards and CPZs, while hammering, pitting will be my main tactic
            (Message edited by neontetra23 on September 05, 200
            • #66
              Reventon: BOX RUSH TO THE MAX AND NEVER ALLOW A CHANCE TO ATTACK!
              Walk Dont Run: SHOCK KILL Wedge Devolution to death and pit it ASAP. AVOID THE FRONT LIKE MAD, and just NEVER ALLOW A CHANCE TO ATTACK!
              • #67
                Richie is back indeed!
                Flaming Hell vs Son of Ripper X
                I think SoR can get this one easily. Flaming Hell to meet the bottom of the pit.
                Squish to do what it does best: squish. One more pitting to notch up for Mr. Stickler please!
                PsycloniZer vs Under Pressure
                Not AJs ideal opponent. Under Pressure to pit Psy after taking a little damage.
                Wedge to flip WDR all over the place and eventually into the pit.
                Reventon vs STAT
                Hey, a match STAT can win! And will win, by a mile.
                Bad match-up for Frank. Eurypterus to pit the damn thing.
                I seem to recall these two met before...Ill say Leprosy Infection for the hell of it.
                Exodus vs Holepunch
                Depends what set-up Liam uses.
                w00t, a Weston battle. Anyway there are no OOTAs so I should be moderately safe from his weapon, although I will do my best to avoid it. Basically wedge it and pit it, my weapon will be my srimech if I get flipped over. Hopefully I have more flips than he does. Only use the flipper offensively if Ive got him on my wedge and near the pit. Good luck Dave.
                Oh dear, not an opponent I wanted to face...basically attack then do the spinny thing and attack the sides/rear with my rear disc, then again with my front disc, and so on and so forth. Ill be more manoeuvrable so that helps, best o luck Stevey-boy.
                Rack up a pitting for Mr. McConnell!
                Flank Attack...just.
                I love the smell of burning robot in the morning. Daniel through.
                Axe-O-Lotl to kill the tracks/wheels/whatever moves System Shock. Yes, I know its invertible but I forgot what moves it. Shut up. :P
                Eternia vs Nitro-Gene 5.0
                Meh, I actually think Paul will win this one. It IS the only Nitro-Gene thats in weight, anyway.
                One more pitting by Alex Holt to end the round.
                Looks to be a killer, Rich!
                • #68
                  Tactics and predictions when appropriate
                  Assuming this is done 2 fights at a time, then SOR X and Squish to move on.
                  • #69
                    Haha I can try out my horizontal crusher against a FBS. His 90 cm fits nicely within my 150 cm wideness, lol. A hit within my claws will make his weapon scrape against my 3,5 mm Hardox and slow it down, using my claws will give me the possibility to pit it .
                    Dont let him scoop me, lol. As long as my wheels remain grounded I still have the 6WD combined with the LEMs, which should anable me to push it to hell and back. The saw and the lifter should help me damaging its wheels. Pit ASAP.
                    • #70
                      «Flaming Hell vs. SOR X»
                      Im going to drive straight in with my front wedge. This is a powerful spinner but I think my 6mm Hardox wedge can take it. That should slow the cage down and allow me to get a good attack in. From there Ill go in with the wedge again and flip Flaming Hell over. Im not sure, but I dont think it can self right. If it can then Ill just try to repeat those tactics as much as possible. Another option is to try and damage the cage itself with my own spinner.
                      «PsycloniZer vs. Under Pressure»
                      This is going to have to be a case of hit and run. Under Pressure is a very big target to hit, so quite simply Ill spin up and try to get as many hits in on the body as possible. There is plenty to hit. The armour isnt the thickest either so causing some damage is quite possible. If I can get around the back I could potentially cause some damage to the ram and other internals through shock damage. Ive just got to keep to the sides and rear.
                      For the other battles Ill go for Squish, Wedge Devo, STAT, The 6isc, Achilles, Holepunch, Wedginator, Troubloon, Nidhogg, Back to Rock, Sacrifice, System Shock, Nitro-Gene and Black Panther to all go through.
                      • #71
                        Liams tactics and probably wrong predictions
                        SOR X, I would guess, but it could go the other way.
                        Squish. Simple as.
                        Two good robots, I think PsycloniZer has the edge.
                        Easily the VFT6 champion.
                        Reventon vs STAT
                        STAT, probably.
                        dunno what EE is
                        Achilles
                        Exodus vs Holepunch
                        nooo... Holepunch is one heck of a vapour, but it has dodgy self-righting. This is how Exodus will be kitted out:
                        Front wedge at 30*
                        Rounded rear
                        Track coverings with barbs
                        Weapon Setup 1
                        Torsion sprung skirts on the sides
                        Top/Base= Red
                        Front/Back= Yellow
                        Sides= White
                        Skirts= Pink
                        Tactics are to try and flip it against a wall, from where it cannot self-right. If I cant do that then just try to throw it around and get it in the pit. Good luck Leo
                        Flipping Hell.
                        Troubloon 6, I think.
                        TMTHY, probably.
                        Flank Attack, I guess.
                        I think this is very close, but due to the clever strategy I think the clusterbot will go through.
                        LOL, Kodys prediction is pointless as without my tracks Im still fine! Ill stick with the lifting wedge and try to pit Axe-o-Lotl with my pushing power advantage. Good luck Chris
                        Another close draw with a Paul robot in it
                        Seen as Nitro beat Mina though Ill go for Paul.
                        Black Panther. Simple as
                        • #72
                          Axe-O-Lotl to snag a wheel hole then drag System Shock into the pit.
                          • #73
                            Exodus vs Holepunch
                            Get to the rear, bite down as soon as I feel the beak is far enough over the back. that should crumple it enough to make the tracks useless.
                            • #74
                              Since none of us clan flip OOTA, I will open the pit asap, and flip nitrogene over and push in the pit. If nitrogene tries to selfright flip it over again. I have much more flips on board then pauls robot does. I also have the less thirsty drive system so on any war of attrition is in my advantage.
                              • #75
                                Added Tactics for Reventon:
                                STAT is petrol driven, so... Ill push it onto the flames, watch it get all roasted up, and then pit it.
