Velociraptor's Fanfic Tournament: The Comeback
  • #31
    Velociraptors Fanfic Tournament: The Comeback
    Why have you poisted Reventons stats again? Its WDRs that are incorrect
    • #32
      Ok, whats wrong with it?
      • #33
        quote:
        Um... if WDR is 110kg with S28-400s, how can you afford to switch them for LEMs?
        • #34
          Walk Don€™t Run 3€˜n a half
          Weight: 110kg.
          Body Shape: Disc.
          Colour: Green Weapon, White for top and bottom.
          Dimensions: 95 X 95 X 27.
          Drive: 2 X 750w BOSCH€™s powered by 3 X NiCad Batteries.
          Top Speed: 15 mph.
          Feet: 4 X Shuffling Pads with Asmaprene urethane rubber, and this prevents WDR from self-destruction.
          Armour: 6mm Hardox for the ring spinner, and 4mm Grade 5 Titanium for top and bottom.
          Ground Clearence: 5mm all around.
          Weapon: 30kg Ring spinner spinning at about 1300RPM, powered by a LEM-130, and has 6 X 1kg Hypno-Disc style teeth, curved, barbed and jagged to rip armour. This brings out about 125kJ, and if the spinner fails, it can use its Tornado-like pushing power to ram other robots to death. Its also heavily shock-proofed as well.
          Srimech: Invertible.
          Strengfths: Deadly Weapon.
          Weaknesses: Hates Flippers.
          • #35
            ...Bosches are lighter than LEMs, arent they?
            • #36
              Samuel, youre really missing the point, and its bogging up this thread. All you had to do was revert to the original stats
              • #37
                Now I get it.
                • #38
                  Weight: 110kg.
                  Body Shape: Disc.
                  Colour: Emerald Green Weapon, Snow White for top and bottom.
                  Drive: 2 X S28-400€™s @ 36v powered by 3 X NiCad Batteries.
                  Top Speed: 13 mph.
                  Weapon: 30kg Ring spinner spinning at about 1300RPM, powered by a LEM-130, and has 6 X 1kg Hypno-Disc style teeth, curved, barbed and jagged to rip armour. This brings out about 125kJ, and if the spinner fails, it can use its pushing power to ram other robots to death. Its also heavily shock-proofed as well.
                  • #39
                    Have found Martijns stats, so just need entrants from AJ and David Weston. Martijn, I know you said you were entering Back To Rock 2, but Back To Rock 3 is newer so could you please confirm which one?
                    • #40
                      sorry you had to search my stats yourself Rich, I just wanted to reply fast to be 100% sure my spot was guaranteed, lol
                      http://strickenone.proboards99.com/index.cgi?board=thvapourshttp://strickenone.proboards99.com/i...oard=thvapours
                      my stats
                      Did I really say Back to Rock 2? I must have been drunk or so, I meant to say Back to Rock III
                      EDIT: Just re-read my post and I did say Back to Rock III (followed by !!!) after all
                      (Message edited by MajinB on September 03, 200
                      • #41
                        Can I just add Samuel,Reventon didnt injure Felix Guzman, he killed him
                        • #42
                          4.8mm Hardox 600 everywhere???
                          I do no make 4.8mm Hardox600. The thinnest Hardox600 plate that I bring in to the UK is 8mm, so unless you are machining the hell out of my plate I assume that you are having us all on.
                          • #43
                            Okay...
                            1. Who are you?
                            2. What 4.8mm Hardox?
                            :S
                            • #44
                              1. Sams 4.8mm Hardox 600
                              • #45
                                Ah, the third set of stats from the top down. :P
                                Still like to know who Johnny Boy is though. :P
