Velociraptor's Fanfic Tournament: The Comeback
    Velociraptors Fanfic Tournament: The Comeback
    Hi Richard,
    Im another name you probably dont know.
    Id like to enter:
    Holepunch:
    http://www.insaneclown.nl/vapourbots/showrobot.php?id=4http://www.insaneclown.nl/vapourbots/showrobot.php?id=4
    Eternia:
    http://www.insaneclown.nl/vapourbots/showrobot.php?id=1http://www.insaneclown.nl/vapourbots/showrobot.php?id=1
      So thats 11 so far - Ill see how many sign up in the next couple of days (looking at some other tournaments, theres still a few people around who might want to, but 16 will be the limit), and maybe chuck in some realies or give some robots byes into the second round. Thanks to everyone for their messages of re-welcome, btw.
        Welcome back Richard! Great to see you again and congratulations for graduating. Its also great to see my favourite series of tournaments return. Ive got a couple of new designs Id like to try out for this tournament, so please save me a space.
          OMG!!! RICHARD!!! VFT!!!
          RESERVE ME A SPOT!!!
            Wedginator returns to VFT alongside his buddy Troubloon!
            [b]1. http://i276.photobucket.com/albums/k....pngWedginator
              Reserve a place if there is one available please!!!
                And me!
                Welcome back Rich
                • #23
                  Right, so just one place left!
                  • #24
                    Yay! Thanks, Richy! Time for me to test out a few new designs...
                    1) Sacrifice
                    2) Squish Reincarnated
                    Stats here - http://strickenone.proboards99.com/index.cgi?board=teambvhttp://strickenone.proboards99.com/i...i?board=teambv
                    w00t!!
                    • #25
                      Walk Don€™t Run 3€˜n a half
                      Weight: 110kg.
                      Body Shape: Disc.
                      Colour: Green Weapon, White for top and bottom.
                      Dimensions: 95 X 95 X 27.
                      Drive: 2 X S28-400€™s @ 36v powered by 3 X NiCad Batteries.
                      Top Speed: 13 mph.
                      Feet: 4 X Shuffling Pads with Asmaprene urethane rubber, and this prevents WDR from self-destruction.
                      Armour: 6mm Hardox for the ring spinner, and 4mm Grade 5 Titanium for top and bottom.
                      Ground Clearence: 5mm all around.
                      Weapon: 30kg Ring spinner spinning at about 1300RPM, powered by a LEM-130, and has 6 X 1kg Hypno-Disc style teeth, curved, barbed and jagged to rip armour. This brings out about 125kJ, and if the spinner fails, it can use its INSANE pushing power to ram other robots to death. Its also heavily shock-proofed as well.
                      Srimech: Invertible.
                      Strengfths: Deadly Weapon.
                      Weaknesses: Hates Flippers.
                      I will also enter Tsunami from Series 7.
                      • #26
                        Actually, I change my mind, I will not enter Tsunami.
                        Weight: 110kg.
                        Body Shape: Disc.
                        Drive: 2 X LEM-130€™s @ 36v powered by 3 X NiCad Batteries.
                        Top Speed: 13 mph.
                        Reventon
                        Weight: 100kg
                        Shape: Box with skirts all around, and bucket scoop on front
                        Colour: Black with Dark Blue scoop
                        Dimensions: 100 X 75 X 36
                        Power: 2 X LEM-130€™s @ 36v powered by 4 X NiCad Packs
                        Tyres: 4 X Tightly Foam Packed, Asmaprene Urethane Rubber Tyres
                        Armour: 4.8mm Hardox 600 Everywhere
                        GC: 0mm on the front, 0mm with skirts, 6mm without skirts
                        TC: Zilch-o
                        Top Speed: 19 mph
                        Weapon: Mainly Relies on pushing power, but there is a small vertical square-shaped blade on the scoop, powered by a S28-400. The blade tips are diamond coated and its top speed is 6000RPM.
                        Inspiration: Named after a Spanish bull which seriously injured a bullfighter.
                        Srimech: Doesnt need one, its invertible.
                        Strengths: Tough Armour, The Blade, CRAZY PUSHER!
                        Weaknesses: Uh... None?
                        • #27
                          Can you not think of any weaknesses for Reventon, Sam?
                          Entries are now closed - just need entrants from AJ and David, and stats from Paul and Martijn.
                          • #28
                            Um... if WDR is 110kg with S28-400s, how can you afford to switch them for LEMs?
                            • #29
                              http://strickenone.proboards99.com/index.cgi?board=tivapourshttp://strickenone.proboards99.com/i...oard=tivapours
                              You can find Pauls vapours there. If you want to know the reason he cant access them, e-mail me or Martijn.
                              • #30
                                Reventon
                                Weight: 100kg
                                TC: Zilch-o
                                Top Speed: 19 mph
                                Weaknesses: Uh... None except for the exposed (but damn sturdy) wheels
