The K-TOAD tournament
The Killer Toad Tournament
Round 1, Fight 12
Acronyms vs. Hypertension Mk 3
The first robot into the arena today is A Robot with an Even Longer Name Because I Still Believe Acronyms = For the Win, also known as Acronyms. Entered by Frank, this low hexagon shaped machine has a 4-way crusher at the front of the machine, designed to crush other robots from 4 ways, and even if one of the 4 arms gets caught, the other 3 arms can continue to crush other robots to death. The armour is only titanium, but with some polycarbonate on top. It can run upside down, but is slow to self-right (I don€™t get it). It has 2 wheels which are powered and some castors at the front and rear as well. The sides are covered with skirts, but not the rear which is exposed.
The second robot into the arena today is Hypertension Mk 3, Hypo for short. Matt would be looking for revenge as it was a Frank machine which put out Hypo in the last tournament. Nothing has been changed since the robot which got pitted by May Tracks, apart from some new wheels. The robot still has a nasty powerful flipper at the front, Hardox armour and 2 wheels at the back which are powered and 2 castors at the front. Hypo has no skirts, so the sides and rear are open for attack, but thanks to not having skirts, it can turn easier and attack, attack, attack!
So it is the battle of the castors!
Both robots are ready
3
2
1
Activate
Acronyms is away first, using it€™s lems to power it up to speed quickly as Hypo holds back, Matt€™s machine has the advantage in the manoeuvrability war, with it not having skirts compared to Acronyms, and also a slight speed advantage, as Matt sets Hypo off, as both machines are heading towards each other. Hypo dodges and tries to get around the sides of Acronyms, to try and breach the side skirts, however Frank turns Acronyms around quickly and comes onto the attack. Hypo reverses away from the front claws before they can crush the Hardox.
Matt spins Hypo around and comes back onto the attack, in a suicidal mission, heading straight towards the jaws, which are lowered, ready to scoop up Hypo, as Matt spins the wheels, taking Hypo away from the front end, as Frank starts to turn Acronyms around, to try and defend against the flipper, which given one wrong move could put Acronyms out of the arena, both machines are turning around, as Hypo comes in. The first contact is made as the front wedge of Hypo gets underneath the front end and quickly fires the flipper, sending Acronyms over. Hypo doesn€™t need a second chance as Matt puts in forward drive, getting underneath Acronyms, Frank tries to do everything he can think off to escape, as the carbon dioxide starts to flow into the flipper rams of Hypo, firing the flipper up, sending Acronyms up and over the arena fence, as it crashes down onto the camera tracks.
Cease
Frank is unhappy that he didn€™t get to play with his crushing jaw, but Matt is happy, as Hypo moves onto the 2nd round.
Next time it is the 2nd attempt at fight 11 (Flyte vs. Autosim), before the return of the 2nd seed against the legend of Die-Ceratops, in Nitro-Gene 2 (2) vs. Die-Ceratops Re-Invertus.
Round 1, Fight 12
3
2
1
Activate
Cease
. Im not going to use my flipper, unless I have him near the wall, or Im upside-down, in order to conserve them.
