The K-TOAD tournament
The Killer Toad Tournament
Round 2, Fight 1
Who will be the first pair to enter into the arena to fight for the first of 8 places in round 3?
*invites audience member to press the button, as the ties all flash up on the fancy over the top massive TV screen before landing on*
Flyte vs. Turbo Tails
As there is a large gasp from the audience, as the action flashes to the pits, where the interviewer, who shall be named Sally, is getting ready to interview the first 2 Roboteers to enter the arena.
Sally: Steve, you€™re the first robot into the arena for round 2, how does that make you feel?
Steve: Nervous
Sally: You had an easy tie for round 1, so is Turbo Tails up for the battle against Flyte?
Steve: With any luck, my only worry is that the blade on the back of Tails is actually too high for the low Flyte, so it might not be effective
Sally: well that is a bugger, but you do hold the speed advantage
Steve: But it€™s only 1 mph, and due to the way the spinning blade is mounted at the rear, the front isn€™t as low as it should be.
Sally: Well good luck
Steve: Thanks
*Steve and some random guys from the pits push Turbo Tails up the ramp and into the arena to get it set up ready to fight*
Sally: So Aaron, are you happy with your draw?
Aaron: Yes, I am
Sally: And why is that?
Aaron: Although Tails has the upper hand in speed, I have the lower wedge and the rear weapon is mounted too high to do any damage
Sally: You took a while to get Autoism out of the arena in round 1, are you hoping for a faster action this time?
Aaron: Yes, Autoism had that arm, which meant I couldn€™t get it stuck against the wall to get a good attack in.
Sally: Are you using the skirts?
Aaron: I am
Aaron: Thanks very much, and may I have your number as your fit.
*Aaron and some more random guys from the pits push Flyte up the ramps and get it set up ready to fight*
Before the fight starts, this is how the two machines got this far, in round 1, Turbo Tail€™s original opponent, Counter redrew from the competition, to be replaced by Woody, which Steve€™s machine destroyed in a matter of seconds. Meanwhile, Flyte put Autoism out of the arena.
Both Roboteers are ready to fight, as the judge is ready, the announcer beginnings to announce:
3
2
1
Activate
And Flyte is away, Aaron wants a quick fight, as Turbo Tails starts off slowly, before putting the drive into full power, the rear spinning bar is spinning up-to speed, as Steve dodges to avoid Flyte€™s first attack. Aaron spins Flyte around and so does Turbo Tails, as it reverses, aiming for the pit release button.
Turbo Tails spins away to avoid Flyte, but Aaron attacks again, slamming into the sides of Turbo Tails and fires the flipper, Turbo Tail hits the arena floor, bar first making a lovely mess of the floor, as Flyte slams in quickly aiming towards the open pit, Turbo Tails presses the flipper button, as it jumps out of the way, Flyte gives chase and before Turbo Tails can move, Aaron€™s machine is underneath the rear end of Turbo Tails, the bar stopped due to damage it received from slamming into the floor.
The rear wheels of Turbo Tails are trying to get grip, but Flyte is pushing Turbo Tails towards the arena wall and with a sudden burst of CO2, Flyte tosses Turbo Tails over the wall and onto the camera tracks below.
Cease
Flyte flips Turbo Tails over the wall and into round 3.
Next time it will be:
Drilla Killa 7 vs. Nitro-Gene 2 (2)
Round 2, Fight 1
Steve: Nervous
Steve: Thanks
Aaron: Yes, I am
Aaron: I am
3
2
1
Activate
Cease
