The K-TOAD tournament
Im entering my two versions of old robots - Autoism and Nitro-Gene 2.0 (And Im selecting Ntro-Gene to be my seed, seeing as it got second last time
AUTOISM
€ WEIGHT: 100kg
€ ARMOUR: 5MM monocque Hardox on front, rear and top. 4MM Aluminium Boron Carbide for the Sides and Base. Weight Reducing holes are drilled into the Monocque Chassis to reduce weight.
€ SHAPE: Box with Pointed (Triangular) Sides and Rear to lower spinner Effectiveness.
€ MOTORS: 2 x LEM 130 AT 46V = 18HP
€ LOCOMOTION: 4 x VULKALON TREADED WHEELS ON TOP AND BOTTOM ALA BIG NIPPER. EACH IS
€ DIMENSIONS: (L) 80CM (W) 80CM (H) 25CM
€ COLOUR: Black for the body, Silver for the crushing weapon. Now, on top, it has the name €˜AUTOISM€™ written in silver.
€ WEAPONRY: The weapon for this is still a Big Nipper style crushing/lifting arm, but instead of claws to lift with, it has a pair of pliars to lift and crush with. The pair of 3.25mm Hardox pliars, work on the same system as the lifter as the pliars are part of the lifter to avoid being torn out by spinners. The weapon lifts and crushes with a force of 9 Tonnes, using a Razer-like mechanism for lifting and crushing! The new crushing weapon means thats if flipped, the robot doesnt need to self-right.
€ SPEED: 23MPH
€ GROUND CLEARANCE: 0MM - 15MM. 4MM Hardox sprung skirts on the sides and rear make it a nightmare to get under.
€ STRENGTH: Power, Speed and Weapons make it a tough machine
€ WEAKNESS: Weak side armour
And secondly Nitro-Gene 2.0, with a change suggested by Kody(Thanks about the LEMs
NITRO-GENE 2.0
€ WEIGHT: 100kg
€ ARMOUR: 4mm Hardox for the body. Holes are drilled into the slanted sides to allow for a 6mm Hardox flipper
€ SHAPE: Low invertible box with pointed sides and rear. At the front is a Storm 2 style wedge to aid in getting underneath other robots.
€ MOTORS: 4 x LEM 130s at 46V = 36HP
€ LOCOMOTION: 6 Vulkanised Wheels.
€ DIMENSIONS: (L) 80CM (H) 16CM (W) 60CM
€ COLOUR: Black all over with the flipper coloured red.
€ WEAPONRY: A full pressure Nitrogen powered flipper at 1000psi, using a single 80mm ram at 1000psi. The flipper is mounted in the middle of the robot, and is 20cm wide and runs 30cm up the body. Using a 3cm long Titanium strip underneath the flipper, and a heavy flipping arm, the flipper runs completely along the ground. Running on a reverse ratio, the flipper produces 1500kg of force at the tips, allowing me to launch anyone away.
€ SPEED: 19mph
€ GROUND CLEARANCE: 0MM-2CM. At the front, it is completely 0mm. On the unskirted sides/rear, its 2cm.
€ STRENGTH: Pushing power and weaponry.
€ WEAKNESS: High side/rear ground clearance.
I hope these sort you out just fine, Dave.
(Message edited by paulc on January 15, 200
) AUTOISM
€ WEIGHT: 100kg
€ SPEED: 23MPH
) NITRO-GENE 2.0
€ WEIGHT: 100kg
€ SPEED: 19mph
