How Could I Improve...
This topic is closed.
  • How Could I Improve...
    Ive been trying to get this one right for a while...
    Brutalis 2.0
    Weight: 100kg
    Shape: Like Dantomkia, but lower and heavier at the front
    Dimensions: 90 x 90 x 25
    Power: 2 x S28-400 magmotors running at 24v
    Locomotion: 2 x go-kart wheels
    Speed: Should reach about 15mph, average 10mph
    Weaponry: Front-hinged co2 flipper running at 750psi, 1 x 100mm ram, 1 x 5kg co2 tank gives about 15 flips per bout
    Armour: 4mm thick hardox on top and sides, 4mm polypropylene on base
    Colour: Black body, red flipper, yellow and green diagonal stripe skirts
    Ground Clearance: 6mm all round, effectively 0mm due to skirts on sides and rear and wedge at front.
    Turning Circle: 0
    Strengths: Agile, Can ram and flip opponents, capable of OOTA
    Weaknesses: Fairly weak base armour, not LOADS of flips
    Hows that?
      Possible Updates for Brutalis 2.0:
      Replace the 4mm hardox with 5mm titanium.
      Replace the go-kart wheels with Vulkalon wheels.
      Replace the 4mm polypropylene with 4mm titanium.
      Otherwise, there are no problems I can see. You have a great flipper, strong design, and nice colour.
        Dont bother Mark, why on earth would I listen to you?
          Its a pretty big tank, im not sure you can fit that in a 90cm x 25 cm Dantomkia shaped bot. In fact im pretty sure you cant.
          4 mm polypro as a base, you might as well leave it open. You cant bolt anything on it as it warps and flexes all over the place. 4mm hi-grade Aluminum like 7075 or 6061 would be a much better choice.
            What could I replace the tank with?
              You could use two smaller ones, those might fit, or possibly three, although thats a bit overkill.
              Slightly off topic, but would thicker polyprop be good as a base? I was reading something about Agent Orange changing to it after the third wars, because on TV their stainless steel one bent and stopped them moving, could be wrong though.
                Dantomkia uses a 2kg bottle, Perolito and Hades a 3,5kg bottle. If you place that in sideways behind the ram it could fit.
                Polypro as a base, you would need some serious thickness to be of any use, at least 10mm. I use HDPE on the bottom of my feathers, but not as a base plate, just as some armouring.
                  2kg and 1.1kg bottles are the most common in heavies btw.
                    Thanks a lot
                      Sorry to be a pain, but I dont want to overload anymore tournament threads with bad stats...
                      Henry VIII
                      Weight: 100kg
                      Shape: A simple box with skirts on sides and rear and a low X-Terminator-style scoop on the front.
                      Dimensions: 85 x 85 x 20
                      Ground Clearance: Effectively 0 due to skirts and scoop, 6mm behind them.
                      Turning Circle: 0
                      Locomotion: 4 x vulkalon tyres
                      Power: 4 x S28-400 magmotors running at 24v
                      Weaponry: Tungsten tipped axe, powered by co2 at 750psi, 2 x 2kg bottles
                      3mm titanium front static scoop for getting underneath and pushing.
                      Armour: 4mm thick hardox on top and sides, 1mm titanium skirts, 4mm thick titanium base
                      Colour: Black with a gold crown on the back, the axe tip is blood stained and the rest of it painted silver like a guillotine!
                      Srimech: The axe can easily right the bot and the skirts stop it getting beached on its side.
                      LockJaw
                      Shape: Axlebot, like Stinger but with a claw instead of a bludgeon.
                      Weight: 100kg
                      Dimensions: (with claw)55 x 70 x 60
                      Ground Clearance: Its an axle bot, so doesnt really have one
                      Turning Circle: 0
                      Weaponry: Hardox hydraulic claw with serrated edges and lots of speed holes. Top half powered by 1 x M-Mac 400 motor running at 36v, bottom half powered by the same.
                      Armour: 4mm hardox all over, but thats not much as most of it is wheels!
                      Colour: Silver, gold claw
                      Srimech: Invertible
                      Hatchet
                      Weight: 100kg
                      Shape: Low invertible box with a stiff tail
                      Dimensions: (without tail) 60 x 60 x 20
                      Power: 2 x LEM-130s running at 48v
                      Ground Clearance: 8mm sides and rear, effectively 0 at front due to scoop
                      Turning Circle: 0
                      Weaponry: 1mm titanium scoop at front, 50cm long 3cm wide hardox tail with two tungsten tipped spikes in different directions (T shaped tail). When the robot spins this can deliver approx. 65kj upon imapct.
                      Armour: 5mm hardox all over
                      Srimech: Invertible
                      Colour: Gold with name painted in red on top and bottom
                      Son of SLAM!
                      Weight: 100kg
                      Shape: Storm II (box with a wedge on the front)
                      Dimensions: 60 x 60 x 33
                      Locomotion: 6 x vulkalon tyres
                      Power: 4 x LEM-130s running at 36v
                      Ground Clearance: Effectively 0 all round due to skirts and wedge, 6mm behind them
                      Turning Circle: 0
                      Weaponry: Full body hammer/ rambot, 1 x 30cm steel spike that shoots out of wedge to flip opponents or damage wheels, running at 750psi from 1 x 2kg co2 canister
                      Armour: 5mm thick hardox on top, sides and rear, titanium skirts and 4mm titanium base.
                      Srimech: Invertible
                      Colour: Black, gold spike
                        Nothing particularly wrong with most of them...for SOS you might have trouble getting the drive and the pneumatics for the spike in there within the dimensions and the weight, could be wrong though. If I was being picky, Id ask about batteries and what linkage is used for the axe on Henry, and for you to clarify that the dimensions are in CM, but theyre generally good.
                        EDIT - just noticed you appear to have a hydraulic claw powered by electric motors as well, you cant have both :P
                        (Message edited by joeychevron on April 07, 200
                          ooh yeah...Electric and hydraulic..
                          OOPSIE!
                          Thanks Joey
                            My views on ALL of these designs are very good, and LockJaw is very original and all of them seem to be flawless. Mark - do not say anything!
                            My only problem may be Henry VIIIs weapon, because 750psi may be a bit too powerful for its own good. Kody built a robot called Avarice which entered a minor competition in which its axe was so powerful it broke off at the vital moment.
                            Terrorhurtz can smash up Hardox quite badly at 160psi - which why I think somewhere around the 220psi or 140psi is enough. My new robot The Rock is doing 200psi.
                              Thanks Paul!
                              Ill tone down that axe...
                              If I dont, Ill probably end up doing more damage to myself than the opposition!
                              Believe it or not, the inspiration for LockJaw actually came from the first Tetanus in RW5, because after the match against Onslaught Craig said something about Tetanus giving them Lockjaw instead of curing it.It just came from nowhere after that...Funny how its nothing like Tetanus at all...
                                Paul, Liam. Pressure is not the main factor in force. It is pressure x surface area on the ram that gives you the force. then the flow (how fast can you get the gas in the ram) determines the speed.
                                So saying 750psi is too much very much depends on the size of the ram used, and how fast you can fill it. A Dutch robot called Spike uses a FP ram (750-1000 psi) for his axe, but has no more than 1 tonnes of force with his 50mm bore, 150 mm stroke ram. Which is plenty for an axe.
