Shape- Cylinder
Weight- 120kg
Dimensions- 87 X 87 X 30
Mobility: 4 X Shuffling Pads
Power: 5 X 24v NiCad BattlePacks
GC: 3mm
TC: Guess.
Speed: 15 mph
Armour: 6mm Titanium
Weapon: 32kg Spinning Ring with 8 Pussycat-style blades powered by a LEM-170 spinning at 1500RPM
Srimech: Invertible
Strengths: Devastating Weapon, Able to rip through any armour, 1-hit KO, and extremely good pushing power
Weaknesses: Crushers and Axes
I highly doubt itd be able to rip through every single type of armour...a Kj count would help, and keep in mind spinners are better with blunter teeth for shock damage, otherwise yo have a very nice yet useless giant circular saw...
Got an email from the Killertron team. They said I could build a new Killertron in the vapourbot world.
Killertron Mach 2
Weight: 100kg
Shape: Killertron from Extreme 1
Dimensions: 100cm x 60cm x 0-30cm
Motivation: 6 Vulkalon wheels
Power: 2 S28-400 Magmotors powering the middle wheels. The motors are powered by 4 NiCad battlepacks.
Ground Clearance: 0mm at front due to scoop, and 0mm at sides and back due to skirts.
Speed: 21mph
Turning Circle: 0m
Weapon: The team have switched from the geared pickaxe to a new Terrorhurtz style pneumatic system at 210psi. about 3 1kg Co2 bottles power a large ram which gives the pickaxe about 1.5 tonnes of power, while the old pickaxe had only 1 tonne.
Armour: 4mm Hardox
Notes: Components are shock-mounted to reduce shock damage. Hopefully this Killertron will have the performance that the Series 2 Killertron had.
Srimech: The Pickaxe
(Message edited by corsair_lightning on April 15, 200
When Killertrons builder comes in here and posts, saying that he wanted you to make him a vapourbot, THEN Ill believe it, but right now, youre full of ****.
You may have gotten in touch with loads of roboteers, but Ive travelled around the universe in 80 miliseconds, drunk 100000000000 bottles of water without going for a pee and eaten the Sharon Osbournes dog. In one afternoon.
If you claim to have been in contact with the Killertron team, then why did you just post a thread in the Competitors section regarding the whereabouts of Killertron? This seems to be a very interesting story... While you were either making this up or were emailing the Killertron team, you could have been researching into making your own design for an axe robot. Instead you seem to be more interested in not only stealing vapourbots from other people, but now stealing real robots as well. Please stop playing off the success of others and come up with your own designs. If you want to use Killertron, enter Killertron. If you want to change Killertron at all, make your own robot similar to it. Giving it the same name and making up a story isnt required. But feel free to embarass me and upload a Print Screen of the emails.
As for the stats, why are four of the wheels unpowered? What is the ground clearance behind the skirts? How large is your large ram? Other than that it doesnt look too bad.
