How Could I Improve...
This topic is closed.
  • How Could I Improve...
    So how is my stats of Sir Spinalot. Is it approved or not?
      Sir Spinalot
      Weapon - not okay. Length gone overboard, width way too small
      The rest - fine
        How big should Sir Spinalot weapon should be?
          Somewhere within 1.1-1.5 times the body diameter, then it will hit opponents. Width...make it at least 5-10cm. That should be good. Thickness is alright.
          (Message edited by kodster on March 01, 200
            so it should 2000 x 500 x 500 then?
              Probably something like 1500 x 75 x 10 would be better.
                Weight: 100 KG
                Shape: Circle
                Color: Light Blue with a painted USA flag
                Dimension: 800mm x 800mm x 120mm
                locomotion: 4 foam-wheels, the wheels are 4 x s28-400 magamotors with 8 x v24 3600ah battery packs
                ground clearance: 10mm
                speed: 20mph
                Armor: 5mm titanium armor
                weapon: 1500x75x10 titanium spinning bar that runs 1000 rpm with 4 x s28-400 magamotors
                sri-mech: yes, the self-righting bar is a electric linear acutator that is on top of Sir Spinalot
                Strength: powerful weapon
                weakness: vulnerable when weapon is disable
                  Is it approved?
                    A titanium spinning bar with dimensions 1500mm x 75mm x 10mm, will weigh approximately 4.9kg. Going at 1000rpm, it will produce 5.1kJ.
                    Andre, I think you should lower the amount of Magmotors you have powering your weapon and your drive. 2 S28-400s for drive and 2 for weapon, not 4. It will give Sir Spinalot close to around 10-15mph (pick a speed in-between). Also, your bar should spin at 3000rpm instead of 1000rpm. That will produce about 45.9kJ, which is quite good for a rookie vapourbot.
                    If you want to know how I found out about this, check http://www.teamcosmos.com/ke/ke.shtml
                      Secret
                      Fine. Could be a few more details, but it€™s good enough.
                      Joey€™s battle
                      €¦I€™m speechless
                      Sir Spinalot
                      €œthe wheels are 4 x s28-400 magamotors€ - interesting
                      Follow Kody€™s advise and this bot should finally be sorted.
                        Weight: 100 KG
                        Shape: Circle (Like the Revolutionist)
                        Color: Light Blue with a painted USA flag on top of Sir Spinalot
                        Locomotion: 4 foam-wheels, the drive runs with 2 S28-400 magamotors with 8 v24 3600ah battery packs
                        speed: 15 mph
                        weapon: 1500x75x10 titanium spinning bar the runs 3000 rpm with 2 s28-400 magamotors
                        Strength: Powerful Weapon
                        Weakness: Vuluerable when weapon is disable.
                          And its in! Right?!
                            Andre, these stats are a thing of beauty.
                              WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOO-HOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOoO !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!
                                The self-righter should be powered by a linear actuator, not be one. Otherwise I dont see any problems
