How Could I Improve...
Could you also check MeCannibal
MeCANNIBAL
€ WEIGHT: 110kg (Shuffler)
€ ARMOUR: 5MM Titanium on top and bottom.
€ SHAPE: Invertible low cylinder
€ MOTORS: 2 x S28-400 MagMotors at 36V = 12HP
€ LOCOMOTION: 2 x Shuffling pads
€ DIMENSIONS: (L) 80CM (W) 80CM (H) 20CM
€ COLOUR: Black with scary human face with over sized teeth coloured red.
€ WEAPONRY: Ring spinner, made of 8MM Harox, weighing 30KG, powered by 2 x LEM130€™s at 36V to give it spinning speed of 2500RPM and producing 175KJ per blow with a spin-up time of 3.5 seconds. It 2 big teeth made of Hardox that curve out. The teeth are inserted into the body and have rows of Tool Steel spikes on the teeth to dig in. These teeth 5kg each and are designed to send all the spinning energy into one spot rather than small amount into multiple spots. It also has 5 Inches worth of Titanium shock-proof Foam to stop it self-destructing.
€ SPEED: 20MPH
€ GROUND CLEARANCE: 0MM-8MM. It has a full-bodied skirt running completely along the ground that rises when the shell is spinning, but drops when the shell isn€™t spinning. This is powered by a simple 750w Bosch 36V motor and runs at the same time as the spinner.
€ STRENGTH: Scary name and weapon
€ WEAKNESS: Hard to control
MeCANNIBAL
€ SPEED: 20MPH
