How Could I Improve...
Ok, can someone check this out, see if its not too terrible:
NAME: Pending. (I suck at names. Im probably gonna use the next song that would work that comes up on my iPod.)
SHAPE: Box with wedge at front and inverted wedge at back.
COLOUR: Deep blue.
WEIGHT: Around 100kg
DIMENSIONS: L:110cm W:65cm H:23cm
SPEED: 25mph
TURNING CIRCLE:0mm
ARMOUR: 10mm hardox.
GROUND CLEARANCE: 0mm at the front, 0mm with hinged skirts at sides, 20mm at sides under the skirts and at back. (Well, 25cm at the very back, thanks to the inverted wedge.
MOVEMENT: 4 Wheels with Vulkanon tires and aluminium hubs powered by 4 48v LEM130s Powered by 4 NiCad battlepacks.
WEAPONS: None but the force.
SCRIMECH: Invertable.
COLOUR: Deep blue.
SPEED: 25mph
TURNING CIRCLE:0mm
However, Danny, Id add some more NiCads so that your vapour doesnt run out of power after a minute.
10mm Ti skirting is way too thick, halve it at least. What batteries are you using? Turning circle? What hinge is the flipper? It€™s a nice GeForce clone, but there is one serious problem with the flipper. GeForce has the mechanism to reduce its flipping power so that it doesn€™t destroy itself. 1500kgs of force is already overkill, and you are saying that you want to put 3500kgs through the flipper?
