How Could I Improve...
Let me have a crack at it.
Shape: Circle
One thing wrong with that shape: its not 3D.
What you mean to say is cylinder, I assume.
Movement: 4 wheels with Vulkanon treads, two on the bottom and two on the top, powered by 2 S28-150 Magmotors running of 2NiCad battlepacks at 24 volts.
I dont think that would work out well. Go for 4 invertible wheels instead of your current set-up , and also go for two LEM130s for motors, and run them at 36 volts, as this will give you a good boost of power. Also, what batteries would you use with those motors?
Weapons: Full body spinner powered by an etek running at 36volts, which can deal out around 80kjs of power
Its not a full-body spinner if its invertible.
The current terminology is ring spinner. Also, youre going to have a hell of a bad time running an Etek at 36 volts. Go for 48v. Also, what teeth is it using? How much does the entire weapon weigh?
Armour: 8mm Titanium
What are you stating this for, the top and bottom, the ring, or everything?
Other than that its quite good.
Shape: Circle
What you mean to say is cylinder, I assume. Movement: 4 wheels with Vulkanon treads, two on the bottom and two on the top, powered by 2 S28-150 Magmotors running of 2NiCad battlepacks at 24 volts.
The current terminology is ring spinner. Also, youre going to have a hell of a bad time running an Etek at 36 volts. Go for 48v. Also, what teeth is it using? How much does the entire weapon weigh? Armour: 8mm Titanium
