The Crash & Burn Tournament 2
geez Kody, really giving it all these semies arent you?
Semi-Final 1, Round 2
Axeon (13) vs. Infusion
I believe Paul makes a comon mistake in his prediction, you cant win a fight by merely surviving hits. If youre right, and Axeon WILL survive hit after hit and remain undented, hell still lose the JD on agression. I believe an unlucky axe-blow on the spinner may do Axeon more damage than Infusion, I think in the long run Infusionll win on a JD based mostly on damage (either that or whoever is the most aggressive will win).
Killotine: EVO (9) vs. SUNCUST
Haha, axes are doing well this time of the year. SUNCUSTll have a hard time to get a good grip in on Killotine, with the skirts and wedge, while Killotine does have an easier time getting underneath the front of SUNCUST, which is partly unprotected. A good grip on a wheel house will leave SUNCUST in a deadlock.
...Double Whamlet is out now, and SUNCUST just turns around to greet him, Killotine trapped helplessly in the jaws. WHACK! Whamlet€™s twin axes find the 15mm polycarbonate and strike right through them! That is one powerful twin axe. A lift from the plow arm and both Killotine AND SUNCUST find themselves upraised a bit, as Whamlet forces them back into the CPZ. SUNCUST€™s rear end thus meets DBM and sandwiches the house robot spinner. The Watcher decides to burst in at this point and tackles Whamlet. Tony gets the message as well and SUNCUST lets Killotine out from the jaws, and surprisingly Killotine is still mobile, in fact quite mobile. The Scottish axebot spins around and points the wedge at SUNCUST again, driving right into it. Hey hey! SUNCUST is still unable to get under Killotine from that point, and is carried to the wall on the wedge! WHAM! SUNCUST goes flying to the side and back on his wheels, and retreats before Killotine can resume his onslaught. What onslaught, though? I didn€™t see the axe come down last time...SUNCUST spins around and this time tries to avoid a frontal collision from Killotine, failing as Killotine slams into him from the corner, penetrating the wedges but the angle is off, sending SUNCUST away early, and he comes around and tackles Killotine. RIGHT IN THE EXPOSED SIDE! Killotine tries to ride out from around the jaws but they close a bit quicker than he expected, and hey, look what Tony caught!
