Something to think about.
As far as I was aware RR events fall under the FRA rule set (correct me if Im wrong)? And to be frankly honest if you arent a member of the FRA what does it matter to you if the FRA rules do or do not change? If you arent a FRA member you do not need to build to its rules and standards.
Also you missed my point, its a weight limit. You dont have to use 100% of the weight limit. If the limit increases it doesnt mean you need to scrap your machine and start again, you could either leave it as is or modify. Should the rules change sometime in the future (note SHOULD), if you choose not to take advantage of an increase its upto you.
Personally Im against the increase, but the way you talk about it is like is some great conspiricy to instantly change a rule by the evil money extorting FRA. How I see it, Geoff is trying to gauge interest on the subject - not make it law as you are implying.
If you feel so strongly about your opinions why dont you ask to attend one of the meetings? At least then you could express your views directly to the FRA board without going through what you call a flawed system.
Thats me done, cos I aint wading any further into this fictional hornets nest.
