Re: Graupner motors
Right. I am going to try and make this as clear as possible, my previous post obviously wasn't.
will i need more than 85amp?
No. 85A is plenty to take 4 drill motors running on 18v.
I'm thinking of either dewalt hammer drills (which i found out that the motors of the b&q 14.4v one would be fine and i.would just need a new gearbox)
Dewalt motors are odd shapes. It is very unlikely they will fit the cheap gearbox.
Adding other motor to another gearbox is complicating things (trust me, I've had to because I had no choice), and its also pointless when you can buy a ready made unit (Argos/B&Q normal drills)
maybe graupner motors
Not yet. Get a working robot before you upgrade.
doubt they will pull over 85amp but i could always get a 190-200amp hobbyking http://www.hobbyking.com/hobbyking/stor ... 5FESC.html
i would need 4 i think
and i would have to hack them brushed to brushless
These ESC's are for brushless motors. YOU cannot hack them to become brushed motor ESC's. AFAIK there is only one roboteer that can, and he is a lot smarter than you (and me for that matter).
As far as speed controllers are concerned, buy a speed controller that is SUGGESTED to you. We suggest them because they have been proven in combat.
It is not a good idea to buy something, blow it up and then buy one that does work. Better to go with what is known to work already.
The Botbitz 85A controllers (2 of) will run 4 standard drills at 18v without any problems.
If you plan to use 2, 12v drills at 18v, the 25A will do fine.
I hope this helps.
I hope this helps.
