Graupner motors
  • Graupner motors
    hi all i would like to know what people think would work best for a high power featherweight
    would 2 speed 900s or 4 speed 600s be better for torque and speed etc
    in theory i suppose the 4 speed 600 will have more power higher current draw and all that
    i also found these http://www.modelshopleeds.co.uk/catalog ... ts_id=5219
    i thaught speed 500s would be more expensive
    i also intend to build an actuator for the lifter
    would a.wind up car jack be too hard to use as i am not exactly on a gimpson budget.
    thanks
    Re: Graupner motors
    more info
    the design will be inspired by robotwars series 2-3 bot Griffon http://robotwars.wikia.com/wiki/Griffon
    i will also need gear ratio advise and wheels
    will 85amp botbitz be enough?
    thanks in advance
      Re: Graupner motors
      Technobots gears are really quite thick for mod1 and they cost more than the.motors i think ls4 uses speed 600s. Anyone got advise on anything
        Re: Graupner motors
        Gimpson motors, linear actuator. KISS
          Re: Graupner motors
          I would just go with drill motors for your first fw. The gearing will be expensive and the gearbox has to made with a lot of precision. I think a drill motor is equivalent to a speed 500 motor so in theory 4 drill motors are more powerful than 2 speed 900s. I think the botbitz controllers would be fine on 1 speed 900 but possibly not 2 speed 600s.
          Or as jonny said go with gimsons if they are in your budget. And yes a car jack would be fine for a linac.
            Re: Graupner motors
            LS4 does use speed 600s but with drill motor gearboxes, it originally used drill motors but we ran out after breaking them with the shocks.
            Drill motors work fine and we use them in most featherweights we have built, Max is right if you are unsure then its best to use them first. It can be very difficult to make your own gearboxes work reliabily.
              Re: Graupner motors
              Ok i will save the super 4wd robot for christmas and try a cheapy drill bot
              instead of a car jack i might use m8 threaded rod attatched to a drill and gearbox
              i may use this as a thread for my further qustions invthe future but fornow thanks for.replying
                Re: Graupner motors
                dont go into metric studding, we used m12 and the teeth wore daown really quickly after a couple of lifts.
                since I changed to car jacks we never had a problem
                  Re: Graupner motors
                  OK
                  would 6mm nylon 6 be enough for a gearbox?
                    Re: Graupner motors
                    We used an M10 rod and having lifted our sofa at least 3 times and been in 10 battles, the thread is good as new. Depends on your ratios I suppose. We could lift a featherweight comfortably.
                    As for drive, I'd agree that drills are a good starting point. We used (and will use) four 12v cheap drills with 100mm wheels, over-volted to 18v. The result is plenty powerful, and it can do 10mph.
                    If you go the drill route, I can't help but say, get all metal gears for the gearboxes. We didn't, and this happened: http://s1088.photobucket.com/albums/i32 ... 012402.jpg
                      Re: Graupner motors
                      We have been looking at a high torque, high power robot for our second machine so we have just been through most of this, minus the actuators.
                      Building your own gearboxes is hard and comparatively expensive to say the Gimsons. 4 of those will give you loads of push and make it nippy but still drivable (with practice; which I haven't got). You could even go for 6 with the robochallenge wheels and that would be a good powerful machine.
                      The only thing to change about that is that the robochallenge wheels are a little hard and thus slide on the Hardox floor. If you design it in for future development, banebots do 3 different hardnesses (shores) of wheel. Go with the 40 shore 98mm and that will give you more traction, in theory. You could even go 30 Shore but they are very soft and would grain up like F1 tyres after a while. your choice
                        Re: Graupner motors
                        our ones were gradually wearing away after our second event and several big lifts the thread sheered right off and jammed our lifter open
                          Re: Graupner motors
                          http://www.gliders.uk.com/products.asp? ... =&sort_by=
                          there is a price table
                            Re: Graupner motors
                            i am not on a giant budget and about £20 a motor is what I'm after
                            can anyone point out the best motors available on that budget
                            thanks
                              Re: Graupner motors
                              GR01's £23.
