RC cars have brushless motors that go in reverse.
quite a lot though.
would a drill crusher really be able to crush through thick polycarb?
have RC car motors been used in combat before (brushed ones?)
thanks dave (sorry i forgot the obvious reason.)
Yeah brushless motors can reverse but you need a special kind of controller to do that (which is why I said 'generally') which is why you pay so much for the RC cars with that function.
A drill motor crusher, as its been said, wouldn't be very effective as a crusher (might bend some plastic) but would be fine just to pin robots down so you can push them down the pit and such.
And he's right Ben, he hasnt mentioned using 900's for a few posts now .
ok i will now.shut up about brushless.
callums fw chassis that's for sale seems good to work on as a first fw.
i will have more experience if i build it myself though.
and it won't take my 7week summer holiday (God they're long) to fit speed control and add batteries.
cheers
i know i said i.would stop with brushless ideas but this is for an RC car.
1100+ watts http://item.mobileweb.ebay.com/viewitem ... 6176661487
could you use 2 escs.on each one?
this is just for extra info i am probarbly not going for a brushless drive.
although it won't cost as much as satanix, i just posted the link because it looks cheap.
edit: the motors and wheels from callums fw would be good as I'm not building a flipper.
flipper body's should have a fipper
Shipping: Not Available to United Kingdom
Item location: Hong Kong, Hong Kong
Ships to: United States, Canada See exclusions
Please do a bit more research before posting things, sit down with a pen and paper and work it out for yourself then post questions about the build. It took me about 5 seconds to see that it wasn't available in this country.
Don't use brushless at all, forget they exist for the moment and use brushed motors. As a tip, if you have a working robot and therefore understand the basics about how its done at FW level people will take you more seriously, partially because of that very fact and partially because you'll see that what you're asking about wont work. Incase it needs saying in blunt terms, some people are getting quite annoyed.
You could easily turn the flipper into a lifter powered by a drill motor and threaded rod and nut actuator.
That would be simple and very cheap and give you a working robot.
Either do that or make a simple rammer like everyone is suggesting. You will learn a lot more from building it yourself though.
