Login or Sign Up
Logging in...
Remember me
Log in
Forgot password or user name?
or
Sign Up
Log in with
Search in titles only
Search in Featherweights only
Search
Advanced Search
Advanced Search
Forums
Today's Posts
Member List
Calendar
Blogs
Articles
Groups
Forum
Bot Building
Featherweights
If this is your first visit, be sure to check out the
FAQ
. You may have to
register
PMEUMATICS
Posts
Latest Activity
Photos
Search
Page
of
12
Filter
Time
All Time
Today
Last Week
Last Month
Show
All
Discussions only
Photos only
Videos only
Links only
Polls only
Events only
Filtered by:
Previous
1
2
3
4
5
6
7
8
12
template
Next
Thunder arrow
Member
Aug 2010
375
Share
Tweet
#61
4 October 2010, 14:48
Re: PMEUMATICS
Originally posted by
Thunder arrow
is there a website that sales clylinders
max about £50
Theo
someone please help me!!!!!!!!!!!!!!
Post
Cancel
woody
Member
Oct 2003
1674
Share
Tweet
#62
4 October 2010, 15:03
Re: PMEUMATICS
http://www.airlines-pneumatics.co.uk/we
... de=S030100
Post
Cancel
Thunder arrow
Member
Aug 2010
375
Share
Tweet
#63
4 October 2010, 15:17
Re: PMEUMATICS
should i use 1/4 or 1/8
i have some 1/4 in my house
Theo
Post
Cancel
Thunder arrow
Member
Aug 2010
375
Share
Tweet
#64
4 October 2010, 15:23
Re: PMEUMATICS
would this work:
http://cgi.ebay.co.uk/Parker-Double-Act
... 563a86a93f
Post
Cancel
Thunder arrow
Member
Aug 2010
375
Share
Tweet
#65
4 October 2010, 15:43
Re: PMEUMATICS
is 1/4 4mm too???????????????????
Post
Cancel
jonophilpott
Member
Sep 2010
67
Share
Tweet
#66
4 October 2010, 18:04
Re: PMEUMATICS
25mm to an inch
Therefor just divide it by 4 = about 6mm
Post
Cancel
woody
Member
Oct 2003
1674
Share
Tweet
#67
4 October 2010, 18:12
Re: PMEUMATICS
Ummm...
BSP - British Standard Pipe threads are odd as far as sizing goes.
http://www.teamonslaught.fsnet.co.uk/threads.htm
A 1/4 Pneumatic Port would be a 1/4 BSP thread and actually measure 1/2
The plastic / nylon tube to connect everything together will be metric and the size will refer to the actual measured Outside Diameter.
Confused?
The cylinder seems ok...it has 1/8 bsp ports and a 10mm x 1.25 pitch thread on the rod.
... _Technical Catalogue-UK.pdf
PIA-S025DS-0080
PIA = Model 25mm bore 80mm stroke
Post
Cancel
Thunder arrow
Member
Aug 2010
375
Share
Tweet
#68
4 October 2010, 18:35
Re: PMEUMATICS
by the way the pneumatic website dosen't work
so would this:
http://cgi.ebay.co.uk/PNEUMATIC-CYLINDE
... 1975330253
fit 1/4 bsp or not?
or this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?
... K:MEWAX:IT
Theo
edit: is 1/4 copper wirer work?
Post
Cancel
woody
Member
Oct 2003
1674
Share
Tweet
#69
4 October 2010, 18:41
Re: PMEUMATICS
CLICK HERE
The first cylinder linked to is probably a 6mm ( metric port )
The 2nd gives specs ...
Port Size: G1/4
Heavy
Duty Construction
note the emphasis on HEAVY
I have no idea what you mean by 1/4 copper wirer ??!!
Post
Cancel
Thunder arrow
Member
Aug 2010
375
Share
Tweet
#70
4 October 2010, 18:46
Re: PMEUMATICS
sorry i mean 1/4 copper tubing
Theo
Post
Cancel
woody
Member
Oct 2003
1674
Share
Tweet
#71
4 October 2010, 18:53
Re: PMEUMATICS
Yes ...you could use 1/4 copper tube or pipe .... you will however need to source the correct fittings and olives.
I'd recommend nylon or plastic together with push fit fittings.
1/8 ports on the cylinder and valve together with 6mm o.d. tube should be fine for your proposed set up.
Post
Cancel
Thunder arrow
Member
Aug 2010
375
Share
Tweet
#72
4 October 2010, 19:48
Re: PMEUMATICS
Ok thank alot
Post
Cancel
Thunder arrow
Member
Aug 2010
375
Share
Tweet
#73
4 October 2010, 20:10
Re: PMEUMATICS
Would this be right
http://www.technobotsonline.com/nylon-t
... ral-m.html
and is that 1 meter long
Post
Cancel
woody
Member
Oct 2003
1674
Share
Tweet
#74
4 October 2010, 20:19
Re: PMEUMATICS
yes and yes
Post
Cancel
Thunder arrow
Member
Aug 2010
375
Share
Tweet
#75
4 October 2010, 20:22
Re: PMEUMATICS
Thx am going to buy some
Post
Cancel
Previous
1
2
3
4
5
6
7
8
12
template
Next
Yes
No
OK
OK
Cancel
Close
