PMEUMATICS
    Re: PMEUMATICS
    Here's a std type pneumatic diagram.
    [attachment=0:3sfmg295]PNEUMATIC%20DIAG.JPG[/attachment:3sfmg295]
      Re: PMEUMATICS
      So would my 1 work
      But how do u split the battery (1 to the speed controller and 1 to the battle swich
      or do u do something different
      theo
        Re: PMEUMATICS
        Lets start with a simple battery , motor and dual speed controller setup.
        NOTE that the receiver is usually powered from the speed controllers BEC.
        http://homepages.which.net/~paul.hills/Emc/BecBody.html[attachment=0:fn44r4tl]bat motor controller.JPG[/attachment:fn44r4tl]
        Questions?
          Re: PMEUMATICS
          No prob with that but how do u give power to the esc and the weapon
          because the pic that was on tecnobots said that the battle switch (for the flipper) needed
          to be conected to the battery
          Theo
            Re: PMEUMATICS
            an inside of my robot
              Re: PMEUMATICS
              The supply to the Battleswitch (for your weapon) and the supply for your ESC are wired in parallel... so after the safety link you would have two red (positive) wires, one goes to the ESC and one goes to the Battleswitch. Then two black wires from the negative side of the battery, one to supply the ESC another to the switch.
              (BTW, please can you just use basic .jpg images? I have no idea what a .pptx file is nor can my computer open them)
                Re: PMEUMATICS
                more pics
                [attachment=1:3itgvhd1]bat motor controller.JPG[/attachment:3itgvhd1]
                [attachment=0:3itgvhd1]battle.jpg[/attachment:3itgvhd1]
                • #23
                  Re: PMEUMATICS
                  soz for ur computer
                  i think i get it
                  be back with u so with more Q probs
                  Theo
                  • #24
                    Re: PMEUMATICS
                    [attachment=0:21uot4ij]inside.jpg[/attachment:21uot4ij]
                    .pptx = power point presentation file.
                    • #25
                      Re: PMEUMATICS
                      yep my mircosoft word will not work :sad:
                      i get it now thx for all the help
                      (u should make a pneumatic guild and get a sticky)
                      Theo
                      • #26
                        Re: PMEUMATICS
                        You might find my webpages helpful.
                        http://www.teamonslaught.fsnet.co.uk/
                        http://www.teamonslaught.fsnet.co.uk/tech.htm
                        • #27
                          Re: PMEUMATICS
                          Thx again just need to buy all the stuff and finsh my frame and get a vid on utube
                          Theo
                          • #28
                            Re: PMEUMATICS
                            Theo
                            Having read through this thread I have one comment on you building a pneumatic flipper, do your research!! Firstly if it's planned well it will be quite cheap and you wont buy stuff you don't need, secondly if you take the time to understand how the pneumatics systems work then you're less likely to get your arm ripped off by your nice new flipper.
                            I wouldn't want to put anyone off going for a pneumatic system without any experience (now that would be hypocritical ) BUT it's easy to miss thing out which are there for your and everyone elses safety like regulators and pressure relief valves etc. Mistakes hurt in a potentially life changing way (not a good way). Woody has some really useful information and you can always turn up to an event (Like Portsmouth or Maidstone) and get someone to run you through how things go together.
                            Andy
                            • #29
                              Re: PMEUMATICS
                              Firstly I have go to an event and asked
                              and I have had 3 month of reseach just on the weapon ok
                              and I am not a dumb 10 year old kid
                              I know what u r saying and I do know safety is no.1 when
                              using a cut or welder
                              Theo
                              • #30
                                Re: PMEUMATICS
                                Hi
                                just going of pneumatics for abit.
                                I have 2 14.4v motors(and gears) and I was woundering
                                do I need 2 batterys in 2 parallel or 2 in series or just 1 battery
                                Theo
