PMEUMATICS
  • #76
    Re: PMEUMATICS
    or you could buy a 30 metre roll on ebay for £18
    Obviously this is 10mm but im sure they do diff. sizes
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
    • #77
      Re: PMEUMATICS
      Yer or just buy 30 times on tecnobots for about £16
      • #78
        Re: PMEUMATICS
        Im currently building too...
        Ive got 5/2 valve with 1/4 bsp ports with 10mm pipe and 1/4bsp fittings on the ram will this be sufficient??
        What regulators you using peoples? I need one asap.
        • #79
          Re: PMEUMATICS
          Your building a feather?
          Your ram size?
          OR ...Download Noel's flipper calculator
          http://www.hassockshog.co.uk/flipper_calculator.htm
          • #80
            Re: PMEUMATICS
            yes im building a feather...
            the ram is a small hydraulic ram... id say it was 30mm wide and the stroke is about 80-100mm
            • #81
              Re: PMEUMATICS
              I'm guessing your bore as 25mm and your pressure = 10 bar
              So........ 50kg's of force divide that by 3 = 16.66kg's
              You'd be able to flip/turn an opponent over but you'll not get any air time ..your also limited to a MAX leverage ratio of 3-1.
              Have you managed to contact Trev?
              BTW ..Your valve and tube/pipe sizes are fine.
              • #82
                Re: PMEUMATICS
                The reg is the last thing I am getting.
                Is a reg from tecnobots good idea or just go to the airway pneumatic thing place
                Theo
                • #83
                  Re: PMEUMATICS
                  Have you got access to a compressor?...If so I'd suggest that you mock up your pneumatics without the bits you still need to purchase i.e. co2 bottle / buffer tank / regulator and pressure relief valves.
                  Try the setup with an external pressure source ...then depending on the results ...make a decision about the purchase of the other items just mentioned.
                  WATCH THE WEIGHT.
                  • #84
                    Re: PMEUMATICS
                    No I havn't got a compressor or access
                    But this is what I need:
                    a reg**
                    nylon pipe 6mm
                    cylinder
                    valve
                    and that's it
                    **where should I get one from?
                    • #85
                      Re: PMEUMATICS
                      a reg**
                      nylon pipe 6mm
                      cylinder
                      valve
                      and that's it
                      Try contacting Trev ...
                      memberlist.php?mode=viewprofile&u=217
                      You WILL need 2 pressure relief valves... see build rules...one for 1000 psi and one for 10 bar .
                      NOTE ...I'm only giving you mathmatical information on the possible performance of your pneumatics....it's by no means a certainty.
                      • #86
                        Re: PMEUMATICS
                        ive tried contacting him but hes not replied for a few days so i taken upon myself to get one and found a nice one on ebay that service is 60 bar and regulates to 10 bar £25
                        How can i increase this force without going above 10bar??
                        thanks
                        • #87
                          Re: PMEUMATICS
                          A bigger bore / volume cylinder and sufficient FLOW to fill it in a relatively short time...
                          • #88
                            Re: PMEUMATICS
                            So ...you want to increase your Power ...Energy supplied quickly
                            Energy = Force x Distance
                            Distance = Volume / Area
                            Energy = Pressure x Volume
                            ( psig x cu-in => in-lbs )
                            Power = Energy / Time
                            Power = Pressure x Volume / Time
                            ( Units = in-lbs/sec)
                            Flow rate = Volume / Time
                            Power = Pressure x Flow rate
                            ( Psig x cu-in/sec => in-lbs/sec )
                            • #89
                              Re: PMEUMATICS
                              dont wanna take the p!55 but could you guide me in the direction of a suitable ram please
                              Ive seen you can use quick exhaust valves for the inlet too :/ ???!!
                              • #90
                                Re: PMEUMATICS
                                Yup oddball QEV inlet valve.....
                                So what is the biggest ram / cylinder that you can squeeze into your design that you can supply with sufficient gas flow?
                                Get it when you find out / decide.
                                Sorry about that answer but it's really difficult to design for someone else with such minimal information.
