PMEUMATICS
  • #31
    Re: PMEUMATICS
    in series, and you could either get 2 x 7.2 volt packs but if your using drills i'd recommend over volting them with 2 x 8.4 volt packs for more speed
    • #32
      Re: PMEUMATICS
      well i am using the drill packs (yes i know the rubbish (1300mah)
      but i cant buy some(well i could get my dad buy them)
      so...
      EIDT: I have 2 14.4v batterys
      Theo
      • #33
        Re: PMEUMATICS
        Wire them in parallel. That'll give you 14.4V and 2600mAh which will provide a more respectable running time. If you wired them in series you would get 28.8V, which is fine, but you would still only have 1300mAh and several speed controllers suitable for featherweights don't operate up to 28.8V
        • #34
          Re: PMEUMATICS
          my dad said series (but i didnt think that would work and blow my esc)
          so thats done
          i will get a frame pic when its done lol
          Theo
          P.S thx for the quick reply
          • #35
            Re: PMEUMATICS
            BIG NEWS
            I HAVE THE NAME FOR MY ROBOT
            (copyright now apliy )
            MY GREAT NAME IS................................................ ....
            NINJA (warrior, stom, Thunder, ect...)
            Theo
            P.S is this name used yet
            • #36
              Re: PMEUMATICS
              Paint it yellow and call it Happy the littlest robot
              • #37
                Re: PMEUMATICS
                thank!!!!!
                errrrr........................................
                NO!!!!!!!!!!
                • #38
                  Re: PMEUMATICS
                  Fine. I'll take my name.
                  But when Happy wins constantly you won't be laughing.
                  • #39
                    Re: PMEUMATICS
                    or i will be laughing when my robot flips urs OOTA
                    who will be laughing then
                    Theo
                    • #40
                      Re: PMEUMATICS
                      The answer isn't as simple as it may seem.
                      You'll need to know / work out the amps used by your setup....versus the amps your battery / batteries have to give during a given time.
                      Try playing with this calculator
                      http://architeuthis-dux.org/torquecalc.asp
                      ..A Harbour Freight motor is probably the equiv of your motors.
                      Cheers Woody
                      • #41
                        Re: PMEUMATICS
                        i have worked out that my robot should go 11 mph
                        (i can run faster that that lol)
                        Theo
                        • #42
                          Re: PMEUMATICS
                          One thing about wiring in parallel, you cannot charge them in parallel (as one pack) so you'll need to make sure you can unplug each pack to charge it seperately.
                          Not a bad idea using the batteries which come with the drills. We did that for our first feather which was more than enoug for the 30seconds it lasted before being retired as utter rubbish
                          It did last a lot longer running round the garden though.
                          Andy
                          • #43
                            Re: PMEUMATICS
                            Thanks for the battery info
                            so
                            I need the batterys in parallel,
                            the batterys + - split (one to the battery swich
                            and one to the esc)
                            the batery to unplug to charge
                            thx again
                            Theo
                            • #44
                              Re: PMEUMATICS
                              got my battle switch today
                              cant do stuf for my robot at my grandmas home
                              Theo
                              • #45
                                Re: PMEUMATICS
                                Do u put this:
                                http://www.technobotsonline.com/22mm-coil-24vdc.html
                                on the 5 port valve stick thing
                                if not how
                                Theo
