Help with disc
This topic is closed.
  • #76
    Help with disc
    there aint nothing wrong with the macarena chris!
    Ive been known to do the odd dance myself.......
    • #77
      Help with disc
      LOL... its just kind of disturbing.
      I dont think hed been drinking either... :P
      • #78
        Help with disc
        At a robot event yesterday I found a problem with vertical spinners no one else has talked about. My robot has a vertical spinning bar powered by an EV Warrior at 12V. The first impact on my opponent was fine, but the second was too good. The torque from the EV pulled my robot over forward and caused me to flip myself. Kind of hard to explain so heres the video of the fight.
        http://www.websamba.com/hellfirelabs/agg_vs_mar.wmvhttp://www.websamba.com/hellfirelabs/agg_vs_mar.wmv
        • #79
          Help with disc
          Solution- better support under the disc. Ive seen plenty of vertical discs that crash themselves downwards into the floor in an impact. Good support is paramount. That way you get all the energy going into your opponent.
          • #80
            Help with disc
            lol go to http://www.hellfire-labs.s5.com/home.htmlhttp://www.hellfire-labs.s5.com/home.html and have a look at the aggressor.
            it does come much more supported than that.
            • #81
              Help with disc
              lol. Saturday was a lot of fun. I managed to break two welds on my spinner. Daniel, did you say the spinning bar was bent?
              • #82
                Help with disc
                Yeah, yeah, all right Aaron, your spinner is better then mine. The bar is bent and chipped and you cracked one of the bearing blocks.
                Also when the robot flipped itself there was no physical damage to it. It was that I impacted with too much area on the bar, this caused the bar to stop and a pure torque was applied to the bar. A reaction torque occured at the base of the bar which turned the robot around it. Basically it was easier to spin the robot around the bar then the bar around the robot.
                • #83
                  Help with disc
                  Sorry for reviving an old thread but Id rather do that then start a new one. I would like to ask for help in perchasing some hardox for a feather weight spinner. The weapon would measure 302mm x 270mm x 8mm for the 2 toothed version. Its simalar to the one pictured in my profile but only made from a single piece. I also have a 1 and 3 toothed version, but theres no point getting fancy just yet.
                  So is anyone willing to help me get this thing cut out of 450 Hardox and sent to Australia? Ill be able to send to copies of the disc in jpeg, dwg, dxf, idw, iges and stp formats.
                  • #84
                    Help with disc
                    Daniel, you should contact Thomas from SSAB in Brisbane who sell Hardox locally. If you call from your work place, you might be able to get a small section directly instead of having to buy a full sheet. Last time I looked at getting a sheet of Hardox, it was $660 for a 3.2mm x 6m x 1.5m of Hardox 450.
                    If you end up getting some local, do you mind if I chip in for some too? I have not heard much about my extremely expensive piece of Hardox 650 lately and Im looking for someting soon.
                    • #85
                      Help with disc
                      No Aaron. I am not looking for an entire sheet of material I wont be able to cut at home. I am looking for someone who has some hardox and would cut it for me. I prefer to have parts land on my door step rather then do any work.
                      • #86
                        Help with disc
                        I didnt say buy a full sheet. Chase up SSAB metals and get a small pieces of Hardox and get it laser cut in Brisbane.
                        Failing that, contact Christian and see if is not too late to get some Hardox 650 cut for you.
