Help with disc
Guys,
We are starting to talk about some very silly RPM here, just be careful if you are thinking about using speeds like this, are any bearings being used going to be up to the job?
Also remember that any teeth on said disc need to be seriously well attached as at those speeds the forces trying to tear them off the rim are colossal!
I wouldnt want to be anywhere near one of these discs if it spat off a tooth, I know, I have seen a tooth part company from a disc at a mere 5000 rpm and that was quite scary enough thank you!
Guys,
