Ah, I missed this in the speed read of the post from last night (thanks Jamie)...
As noted, the tape will be chewed up pretty quickly. I would drill a hole through the bolt that your wheel is on and the hub of the wheel (I see you are using the same type of wheel as Azriel is) and then put a bolt through that to make it all secure. The bolts on the dustpan, countersunk bolts perhaps? Once those two are done, give it a retest and see what that does for you.
Alternatively, for the wheel issue, where you have that washer on the outside of the wheel, get a bigger diameter washer, drill two holes in that and the wheel and bolt them together like that?
I connected the wiring up to a drill battery and took it outside to see if it would run, which it sadly didn't. Seems to be a combination of the wheels slipping on the electrical tape holding them on to the drill shaft, bolts under the dustpans making it too front heavy and catching on the floor, plus the wheels still not having enough ground clearance even with the tyre.
