Originally posted by Maxamuslead
View Post
BOB FW Series
Gentlemen behold.
Spaghetti Junction.
Finally done wiring for the drive, tested the linear just to see if I got the wiring right and made the little safety light so I know the robot is live.
All I need to do now is tape the wires, make some more safety lights, test the weapon a bit more, order some armour and anything else I might have forgot.
Looks nice and messy :P Seriously though, good work so far.
Looks like I may have to scrap the control box for the linear actuator and use a speed controller instead. Problem I got at the moment is that I got tank steering, so the left stick moves the left side of the robot and the right stick moves the right side of the robot. The amps won't be a problem for the linear actuator since a simple fuse can fix that, it's just finding one and sorting out the controls.
Well when I sort one problem out, I get another this time it's trying to charge my battery. It's giving me the 'cell error, voltage invalid' message.
I looked online about this, but I just can't be sure what the best way to fix this.
Also if anyone is wondering what charger and battery I'm using, the charger is an imax b6ac and battery is a 14.8V 2200mAh 35C/70C LiPO RC Battery Giant Power.
It's because the total voltage of the pack isn't what it set in the charger.
14,8V is 4S LiPo.
You can use the charger in a few charge modiï. Charge and balancing charge. Balancing charge is almost mandatory for us.
If you program 4S LiPo and 2A, it will charge any battery that has a voltage between 10.8V and 16.8V.
With balancing, the individual cells are measured, and if 1 gives a too low voltage, the charger won't start either.
