I think you should do this instead of Wolf-E. All you need is a beefy motor and gearbox with an accompanying ESC and you have yourself a, by the looks of it, much better looking machine. Or you could still do Wolf-E if you have reliability in mind.
Originally posted by HereticBlue View PostYou called? Surprised to another person somewhat inspired by Amnesia's mech! Looks very nice, its a bit like a Tormenta 3/Amnesia lovechild. A bushing went missing for the spur gear during my fight with Beauty and Conker so the gears weren't quite aligned anymore but, it managed to keep working without slipping up to the 3rd/4th playoff so it's a very reliable linkage if you use the right mod gears.
Best of luck anyway and looking forward to seeing the finished machine 'do the thing!'
Leave a comment:
Originally posted by Coolspeedbot View PostMore internal designing, featuring rough renditions of brushless motors with gearboxes and trying out a mechanism based on what I have seen being used in another featherweight front hinged flipper called Amnesia.
Best of luck anyway and looking forward to seeing the finished machine 'do the thing!'Last edited by HereticBlue; 2 October 2017, 21:13.
Leave a comment:
A top down view of the tight fit for the motors, plus the battery has a it's foam and holder. Adjusted the wheels slightly.
Leave a comment:
Originally posted by daveimi View PostReminds me of sewer snake.
Leave a comment:
Another Pic with the top plate added. weapon motor and mechanism moved forward.
Thought process behind the design:
The robot as loosely mentioned before will use (hopefully) Brushless motors for drive and weapon using Saturn-16 like gearboxes with the weapon running on a higher gear ratio (64:1) before running a 2:1 ratio gearing for the final stage of the weapon mechanism. As for the drive I'd most likely use a standard gearbox, running the middle wheels directly off the gearbox while the front and rear wheels are run by drive belts. They may need the use of 3D printed wheel hubs with pulleys built in.
As for the materials, most likely some Hardox but the wedge might need to be made of a material that can have bolt holes countersunk so it is flush to wedge bots smoothly.
Leave a comment:
Leave a comment:
Originally posted by dotDominic View PostThat looks very cool, man. Nice and compact as well. I didn't realise you were designing a front-hinger too. If you build this we will need to have a battle!
Leave a comment:
Leave a comment:
So I've looked at down sizing my 6WD bot codenamed CSB. I've also considered using brushless motors, gearboxes, drive belts to run the drive.
(smaller version on the left)
Leave a comment:
Added link covers, made mounts for XT60 connectors. Narrowed the 6WD (currently 48cm x 46cm x 10cm ) bot and arrange most of the mock internals.
Leave a comment:
Leave a comment:
