Looks really professional
Just a heads-up, you can remove those 'flux guards' or whatever, those sleeves that fit over the motor. You just need to lift one side up near where the gap is and then pull them off, as they have a little nub on the inside which fits into the motor casing. Or you can leave them on if you want, it's up to you.
I just find it makes it a little easier to mount the motors.
So after I made the mock up of Wolf-E I was able to better identify where the design was not working and I soon did a edit to the digital design. The main issue was that the frame was not fully designed with the method of how they was going to be bolted together.
Screen Shot 2016-11-06 at 01.42.36.pngScreen Shot 2016-11-06 at 01.47.48.png
Yes, I'll be using bolts with barrow nuts for the frame and another kind of nut for the wheel covers I still trying to find the correct name of. I added the placements to the design.
Yeah or even more so. I just realised you may not even want to fight spinners so it doesn't matter. But if you look here on Beta can you see how it's just one smooth continuous angles and shapes? And how anything nasty trying to get at it would sort of deflect rather than chew? If it helps I can sketch something to show you with regards to your robot when I get home.
http://vignette2.wikia.nocookie.net/...20160517203923
