Yeah sorry I've changed it now, no spec sheet I'm just going on what Mario told me when I brought it from him.
Wraith, the El Cheapo spinner
http://www.scorpionsystem.com/catalo...0/HK_7050_340/
There you go, motor problems solved.
I would try and have a look at the motor though, see how fast it ends up going. Maybe could get it all put together and then try it to see if it runs, if the motor struggles then replace it I suppose. The mechanism you've got seems great for the job, and if the motor still turns it, you can always limit the speed if needs be. I'm not so sure though without knowing the specifics... Brushless is always an option too I guess if needs be!
PROGRESS!!!! Of which there has been none, just disappointment and lots of it. The disc doesn't fit on the drill press so I can't drill the centre hole out, I didnt have any thin cutting discs for the teeth and didn't fancy trying to cut them with the 3mm ones, my circular saw has crapped out so the chassis cutting has to wait and I'm sure there's more, basically Wraith is still just a pile of parts.
