Massacre - Build Diary
    Massacre's weapon pulley, soon to relocate to Harry's shed.
      Cheers, and awesome work Ellis.
        Stuff is turning up, robot is happening slowly.
        Wheels have all had nuts heat pressed into them. Not 100% straight but at the moment is good enough for me. I've got 8 hubs so I've got room to practice/make spares.
        I've done the recessing for the front part of the frame to sit between the bulkheads and have just started doing the finger joints at the rear. Because slightly non-standard (i.e. silly) design it is rather intensive work.
        Connectors turned up, will use these for link. Still waiting on some deans for doing other assorted connections in the robot.
        In case you hadn't noticed these are bolts. 12.9 m10 cap head for the weapon.
        Bits of the weapon. The pulley arrived and it is right nice, cheers Ellis. Got an assortment of bits go go with it. Thrust bearing, bearings, bushings, shaft collars etc.
        Wasn't sure about bearings vs bushings so I got both. Same size although the bushings are a bit longer. Will try those first and if I'm not happy about them I'll switch to the roller bearings. I don't think the bearings will be up to it so chances are I'll keep with the bushings. Got spares for both so I should be all right.
        Mounted in the pulley yadayada.
        Weapon bar hasn't arrived yet. Hoping it will turn up fairly soon.
        Cheers. Harry.
          Double post, sorry.
          Bar has just arrived. Everything plops right into place for full Pretend-O-Bot effect.
          weight is just under 3kg. That's without pulley and similar.
          Big big thanks to Mario for sorting out the cutting
            *cool factor intensifies*
              Compensating for something? :P hahaha
              In all seriousness, that will be scary at 4000rpm
                I 'like' this!
                • #23
                  So yeah my armour needs to be beefed up, looks awesome Harry
                  • #24
                    Was waiting for that.
                    Cheers guys. Some more for you:
                    Mounted the pulley to the bar, only with 2 bolts so far.
                    Pretend-O-Bot
                    And done a bit of frame work, just loosely pushed together for Pretendo Power.
                    • #25
                      So I'll bring some bin bags to the champs yeah? Seriously though that looks amazing
                      • #26
                        That's looking incredible Harry. If we get drawn in a qualifier again hopefully it'll be a much more interesting fight!
                        Beginning to wish I'd left a little extra material on my cross bulkheads for recesses & finger joints.
                        • #27
                          Hatchet looks solid as, so you'll be all right.
                          Cheers Jamie. I'd love to go back up against Drumroll to see if I could take it when its fully working with its posh new frame and drive.
                          • #28
                            Getting the frame together. Shoved a few parts in just to illustrate sillyness of the robot Should come together over the weekend. Also got all the parts ordered. Weapon esc and pulleys should be arriving soon. All the rest of the electrics and that are here. Currently sorting out a room for the champs.
                            Cheers. Harry
                            • #29
                              I bet that'll be crazy when it's spinning at full speed, definitely one to watch haha!
                              • #30
                                Because it will be epic when it rips itself apart? Only joking Haz, looks great!
