Yeah I didn’t mean to come across negative, sorry if I did. I have Asperger’s and it shows at times with me getting the wrong end of the stick.
I just meant if you were worried about money you have a nice drivetrain and 850’s are available and some batteries and weight over the drive would push it in the floor.
I’ve spent hours pouring over the photo’s of the big pushers with their shell’s missing as I’m not a fan of spinners. The one thing I notice is all the battery weight etc. centred over the drive for grip.
Brushless drive sounds nice; you should have a look at that! Also sounds a lot cheaper than I’d realised.
 I do get where you're coming from, but it's literally impossible to get any more weight over the drive in HardWired II anyway, I'll post a photo of it's innards sometime - the motors are touching the top plate and back panel and are back to back because of how small the machine is so I literally can't get any more weight over them. Having brushless, depending on the motor, could mean I'll be able to redistribute the weight a bit more by putting a block of steel or something between the motors. It'll probably be something a bit better than that, most likely a battery or something but you get the picture!
