I think that's all true as far as it goes; here are some extra points to consider:
* As you increase the contact patch and use a grippier wheel material, you need more power to spin the wheel.
* Running a smaller motor may spin your wheels, but its operating nearer its capacity and getting hotter than a larger motor. That's a key difference to the car analogy; cars have proper cooling systems while bots mostly don't.
* The time you need traction and pushing power the most is often when the opponent is wedged up on your bot, giving it more than 13Kg of down-force.
* You can increase down-force dramatically with magnets. I got an extra 10Kg with magnets weighing only 104 grams.
