Just using an identical 2nd stage sounds ideal - you already know it holds up in use. You might get away with a single stage Banebots P60 as a first stage but motors you want have too much torque for a 2 stage P60.
The brushless set-up I have is instant reverse and plenty of other ESCs have the feature, particularly the sensored ones. Its important to download and read the ESC manual before buying anything; the reversing details are often vague. There is at least one Hobbyking sensorless ESC that has instant reverse, I will try to find a link.
Another option is to add sensors to an outrunner. Its been done before and someone even had a kit for it. It only works for motors with a certain number of poles but that still leaves a wide choice. A sensored outrunner would be a fantastic resource for bot builders; it would offer low speed torque, instant reverse and lower cost.
