Re: Tormenta 2 - Build Diary
That's the thing. The motor is by no means huge. Just compared a Speed 900 to the motor we have, a 900 is about a cm longer, and it weighs about 200g more. The output shaft on our motor is 5mm, I think.
It would probably be possible to do, actually. If we had to. Quite a lot of $$$ though.
We did some tests as you saw in the videos, and it didn't seem to struggle at all. It lifted about 5-6kg on a 7inch bar without the further 4:1 reduction on a bad battery when we first got the drill, which would suggest it'll do around 20kgs.
We shall see! We haven't completely ruled out buying a drive motor for a bigger robot as a way to do it. This will lift a FW, I'm quite confident of that, it's when it lifts itself+another machine (which will happen quite a lot I think) that we may struggle.
