Hi guys! About time I make this thread I reckon.
Tormenta 2. We're hoping this machine turns out to be what Tormenta could have been and more. Much of v1 will be reused in this machine. The whole drive train and control system will be the same, but made more reliable. We were very happy with Tormenta's drive so we will be sticking with its drills. All of its reliability problems came from the failure of plastic gears, so we will be using all metal. Speed control wasn't brilliant with the Electronize but it will do for the moment. We may look into more precise control if it becomes a problem.
The weapon will hopefully be more interesting. It's a big-drill powered lifter/flipper style thing, comparable to that of a certain famous American robot.
The chassis will be entirely HDPE (we may use some chopping board in low-risk places to keep the Tormenta spirit!), 10mm base, 20mm bulkheads and 10mm armour all round. If we have the weight left over I am hoping for a big steel wedge on the lifter, spanning more than the width of the robot.
We have 2 batteries, 4 drills, 1 mega drill, chains and sprockets, 3 ESCs, radio battery and receiver, all the wires, and God knows what else, to fit inside. This robot will be smaller than Tormenta. The inside width is 21cm, whilst the length (again, usable inside space) about 35cm.
Think that pretty much covers it. We have made some progress with weapon test rigs, as you can see here: http://www.youtube.com/watch?v=ehbNsEld ... re=youtube
And all photos, as ever, will be going on a Photobucket album, here: http://s1088.photobucket.com/albums/i32 ... menta 2/
Any questions, ask away. In the meantime I'm going to attack the drill shaft, as so far every attempt to secure the sprocket has failed. Next stop: cotter pins!
Ellis
Ellis
