Re: Tormenta 2 - Build Diary
Made some good progress whilst waiting for the Botbitz to turn up. The top plate has been mostly made, it will need some slotting at the front yet. We also have made up the chocks on which the side armour will be mounted. These way just 200grams together, due to drilling 38mm holes in them.
We did that because we realised how close we are on weight. We're going to continue building with weight semi-on-the-mind until completion, and if we end up overweight (think we will) then we'll replace the top lifter bars with ali ones, as the current weigh 3/4kg!
Oh and the HDPE pipe has been attached to the back.
Coming along very nicely. It's doing what Tormenta did, looked the same for months and suddenly in the last two weeks its look changes wildly.
On photobucket you can see some of our PRECISION engineering, including a coat hanger clamped to the workbench which hangs over the already made hole in the machine, the technique being to slide the top plate into position and voil¡! Instant hole alignment.
Oh and also you can see how we drilled the top plate mounting holes into the bulkheads, by putting the robot on a sheet of HDPE and a briefcase, then putting the pillar drill on an old painting.
We're totally at the forefront of precision robot combat.
- that said, the pic of our bulkheads is pretty cool. Each hole has a purpose!
http://s1088.photobucket.com/albums/i32 ... menta 2/
- that said, the pic of our bulkheads is pretty cool. Each hole has a purpose!http://s1088.photobucket.com/albums/i32 ... menta 2/
