I've calculated it in and it came to less than 13kg and i'm only using it for the front, back and sides the base is 3mm steel and the lid will be 5mm ali
best website for working out armour/chassis weights
well got all the motor mounts on now, hopefully have it driving soon so i can do a vid but aiming to change the Argos motors for the ryobi once i get round to it ........ at the mo i cant wait to get it finished and drive it head on into a spinner and see if my weld hold
on laser 2 we have 3mm thick ali checkerplate. it is very good as a lid, it survived getting puunded by battleaxe, so I would say it would stand up to all fw hitters, not so sure on crushers as we havent faced any of them.
ok so far with all main components bar a few bolts the robot weighs 11.55kg and i still need to attach some spikes to the back and a scoop at the front but if my calculations are correct it should come in just under weight, ill hopefully have some pics and a vid up soon maybe of the 2 battling as the is a basketball court near by that ill be great for testing
gonna make 2 more of the bolt on scoops 1 for either side, dunno weather to make them slightly shorter or not though and also intending to to make a few other interchangeable bits for the front just gotta think of something lol .............. any ideas ????????/
oh also done a bit of a test drive on a naff drill pack but waiting on battery's from china for a proper test
