  • Re: 360 - mini hypnodisc
    Or could machine it in to a present for his mum ??? :shock:
      lol!
        Lol, when you over in Leeds mate me n Tom try get your material up to kenny so he can get it done for you
          Kennys busy this weekend doing s10, im on holiday for a week monday, so will be when im back in the country i guess mate. Can come up on the 26th if Kenny isnt busy.
            Come up this weekend and show me what you want doing to the drum and i'll have it done when ya get back from holiday
              Originally posted by mr_turbulence
              brushless escs came from australia today, so i wired them up to give them a go...
              Wasnt confident they'd be any good, but gotta give it to the aussies so far all good, and there tiny...only just double the size of a BR RX;
              there hacked brushless tz85 turnigy escs... 85amp forward/reverse... slammed the motor into full forward/reverse and it worked fine on the bench... in theory nearly all brushless escs can be hacked to run forward/reverse brushed motors apparently... could be the next generation of speed controllers for anything upto heavyweight size in the future.
              have you got a link to these ESCs?
              Cheers
                http://www.botbitz.com
                  Are you going for a Snail Drum design Dave?
                  Unibody, single tooth drum? Looks like a snail from the side, hence name.
                    Would the 25A botbitz controller be enough for a gimson motor? What if it ran off 24v?
                      A 25a ESC for a single Gimson should be fine, but that particular ESC is rated to just 4s, or around 14-15v. I doubt it would much like 24v.
                        well those tz85 hacked esc look very interesting
                        I'm thinking of using speed 900 but in a 4 wheel drive config (driving each side with one motor through chains with a gear reduction)
                        Works in my mind but alot of moving parts so to speak
                        Do you think the hacked tz85 would be up to 900's under load ?
                        Also , out of interest, what size wheels and gearbox ratio will you be running?
                          Depends on a number of things, mainly voltage, but if you're being sensible and follow the specs they're giving you I would say it would.
                            Just look through the Australian forum and check out what they're running off these escs peeps
                              PJ- nope, 2 tooth drum machined from a billet with bolt on teeth.
                              Drums being machined by Kenny soonish hopefully.
                                Drum machined...weighs just over 3kg, will be going around 15000rpm.... just need to machine some bulkheads out of some alumec next....that takes effort though.
