Wow, just wow.
Team Expat - Beetleweight Adventures
Been making progress with Gonzales. I've reworked the drive system a little. Before the wheel shaft was just a bolt locked off on the outer bulkheads and a big horizontal hit would have shunted it into the drive motor. That, and the motor pinion/wheel alignment was off by .4mm on one side which meant that motor had to be mounted crooked to engage the wheel. I couldn't leave this and call what I'm doing an "overhaul". :P
I made some little plates to fix the issues:
The wheel shaft now bolts to the inner bulkhead with an m4 bolt (the stub of thread you can see).
The spacing should now be correct, but since taking those pics I drilled out the hole so that the wheel shaft at motor-end can be adjusted by .5mm in any direction (m4 bolt, 5mm hole). So I should be able to get the gears meshing perfectly.
I made a pair of drive shafts to complete this area of changes/upgrades:
As pictured + electronics it weighs 1180g, I'm hoping I can make new lighter wheels (currently 100g each!) leaving 100-150g for putting steel on the scoop.
Still need to start on the spinner... and rebuild the front of T2... and make sure Rango isn't a fire hazard... 30 days gah.
Cheers.
Have had to focus on some other stuff for a few days, but I have been making steady progress on the new robot. Major picspam inbound.
I started with the main chassis components - Harry squared the alu on the mill and brought the bare blocks over when he visited, the first thing I did was drill and tap according to my CAD:
I devised a mounting method for the wheels which involved making a hub. Making this sucked a bit; too small and easily ruined (I have so far avoided making the second one...):
I then sort of forgot to take more individual part pics, or what I did take was in terrible light on an old phone, so cutting to the chase it looks like this as of this evening:
Next to the not-touched-since-last-post Gonzales for a sense of scale:
So: the motors are mounted, the backplate is done (1.4mm ti), the alu blocks are as holey as they'll get, the HDPE bits need some inserts for top/bottom panels, and one wheel guard thingy is done. I was very skeptical of just 2mm HDPE even being worthwhile, but because it's all under tension (I didn't heat the bends, so they're trying to straighten) and a trapezoid it's pretty stiff. Making that was certainly a learning experience. Second one should take a third of the time.
Will be getting to the weapony stuff before long.Last edited by Ellis; 13 August 2014, 23:08.
Originally posted by Eventorizon View PostThat looks so slick! How did you get everything looking so neat?
I have made the main support structure pieces for the spinner. I started with the more simple one:
And just finished the second one:
Not sure what to do next, either the other-end-shaft-support (which bolts to the more simple piece above) for the brushless or the other wheel cover thing.
Originally posted by Fathersplat View PostSomebody give me a job so I can buy the tools necessary to make stuff this good.
