Lol thanks guys. Hacksaw to begin with, lots and lots of filing, a touch or two on the bench grinder to accelerate removing some bulk and some holes courtesy of the pillar drill. I don't have a good/big vice, wish I did lol. Each one took maybe 7-8 hours from marking out to taking pics.
Team Expat - Beetleweight Adventures
2826 1200kv NTM, picked for it's tininess.
Generic pick-any-of-these 30a BlueSeries thing from Hobbyking. Drives are 10a botbitz.
Turnigy (not nano-tech) 800mah 35c 3s pack, which should give me *just* enough run time with the small motor.
The weapon reduction is roughly 1.44:1, giving a theoretical top speed of 10,000rpm. I'll be chuffed with 8,000 real-world.
That is well built. No real catch-points besides the bolts. Should be enough weight over the rear to make it drive properly. And if that motor does what its supposed to do it will be a dangerous little machine... makes me feel like I am once again overkilling the weapon on my new beetle but what they heck, it will be fun.
Spent the past few days poking Rango so progress on this has a slowed a little. Some new bits though:
Other-end-shaft-support for the brushless. Little bronze bushing (flange is .8mm thick...) and an equally fiddly ti plate.
Made the pulley that goes around the motor this afternoon and took delivery of the belting.
Disc pulley/bearing supports next, then I'm not far from a weapon test.
