There seems to be a problem .As several Dutch competitors dont get the whole idea about the power on LED. Also, carefull reading of the rules gives a few other questions.
Purely in the rules we have this.
4.3. In addition to the main power light (See. Batteries and Power no. 6.8.) showing the main power is activated. It should also indicate if the robot is in €œfailsafe€Â, €œoff€ or €œzero€ position.
On the FRA mainpage we get this rule.
As off 1st January 2004 all middleweight, heavyweight and superheavyweight robots running at FRA events will be required to be fitted with an exterior power light as a clear visual indication of whether the robot is in a powered state (i.e the removable link is in and the robot is active)
Now, what is realy needed? And how and in what colors.
I can see some confusion brewing. If Team A uses a red led to indicate Link in and team uses B a red light to indicate failsafe active on channel 1
Also, all our channels are failsafed(except for some who failsafe 1 complete shut down idea)Do each need a failsafed light?
Lots of questions needing to get an answser
