Power/failsafe LED
Lee, you know it worked when you tested it, but would you trust it to still be indicating correctly when your robot has been damaged in the arena?
If none of the lights were still on would you think it was then safe?
Can an event organiser be sure that the indicators are correct just because you say it works correctly?
Would you trust some one elses indicator system on their robot?, I would not, and by that logic I cannot trust yours either, just on your say so.
I am not saying that yours does not work, just that it is not possible for me to know that it, or any one elses indicator system is working correctly at all times.
When the link is in, that is the only warning that you need to tell you that the robot is dangerous.
The lights are fine for you to know that every thing is powered up, but when they are not lit does not indicate that they are not powered up, that is the crucial point.
 .  Dont put people off going to your events as Im sure that many wont go if the FRA dont approve your event.
