Power/failsafe LED
Rodger, you are right in that at the end of the day it comes down to the insurers who set the minumim standards but I dont see why you are against the light. If all robots require a light and you put the link in during a tech check and it does not come on then it fails. If its on when the link is out then it fails. Even in our robot we have had wires short to the chasis on a number of occasions and if that happened with a wire before the link it is possible for it to become active. A light would indicate this. How else would you know unless you did a full tech check after each fight. We have two power lights one across each speed controller. Whats the point in the FRA if people dont follow thier guidelines. Read some other threads you will find alot of people wanting to standardize the rules for everyone not just the UK. It will take alot of time but hopefully it will happen. I must point out that I dont speak for them but Im sure that they will listen to you as you do have alot of experiance and have been doing this longer that me.
Jim, I would have to check to be certian but I thought it was a couple of mA.
I should also point out that I dont like the failsafe light idea as it stands and using the PCM Rx would not be allowed under this rule as you cannot be sure they are in failsafe without using a dedicated channel and even then its not certain that it will work unless setup very carefully. PCM Rx are the best for rejecting interfeance as they have active error control.
