FRA UK Featherweight Championship 2014 hosted by RoboChallenge
  • Its made of spit and kleenex with a small amount of polycarbonate The top is definitely the weakest part.
    • That's what I like to hear! Just need to avoid the huge spinny thing of death and I'll be fine
      • Originally posted by overkill View Post
        To be honest with you, I think that's the same with most machines, mine is definitely the same. 6/7ishmm hardox round the sides, 2.5mm stainless on the top, with some 3mm hdpe in choice places! The power of the spinners means that side armour definitely gets prioritised I think...
        • OK, I am about ready to pack Mr Mangle up; I don't have a build log on the forum, so here is a quick weapon test video: http://www.robowars.org/forum/viewto...?p=86278#86278
          • so bin bags for me then yeah?
            • Mr Mangle still only has a 3mm polycarb top; I am hoping those roll-over hoops will act as extra axe protection from front & back attacks. Look at it this way - you have extremely thick armour and Mr Mangle is definitely not a NST, Binky or 720
              • Even thicker now , in all seriousness i think our fight could potentially be very good, my axe could easily get through your top panel but your beater could chuck me around quite a bit and Loki despite it's thin armour is built quite strongly and looks like it might be a tenacious little thing. I'm very much looking forward to it (at least more than i'm looking forward to having 2 fights with Binky).
                  ...you have extremely thick armour and Mr Mangle is definitely not a NST, Binky or 720
                  I can't believe you put Binky along side NST and 720!
                  • Perhaps its because I never have much luck with vertical disks, but Binky is my 'most feared' UK bot.
                      Why, any particular reason? She only got 1 or 2 good hits in last year. 720 could send Mr Mangle back to Aus for free if it gets a good hit and NST could flat pack it for you if you would prefer to take it on as hand luggage.
                      • NST probably won't do much to mr mangle. Maybe sheer a couple of bolts...that frame is mega strong... And against 720 it would just be a flipping match. Be good to see the brushless drive running.
                        • That's right Dave, having run an under-cutter for years, I know what it take to make a bot proof against horizontal spinners - the front corners are 17.71mm thick and the back corners are 8mm with large gusset plates. In the worst case of losing the weapon against a horizontal spinner, I can just drive backwards and let the other bot throw itself in the pit or over the wall.
                          With vertical disks, Mr Mangle will usually get flipped and if its near a wall, then its game over. I think the hoops will surprise everyone but they are not perfect if flipped into a corner or the pit etc.
                          • How thick is all the Ti on Mr mangle, and I am guessing all grade 5? Looks around 4mm or 5mm in the pictures on your build thread.
                            • Got one of mine working again after some fire happened at Colchester :P, onto Flow now:
                              https://www.youtube.com/watch?v=9zBbSARTJIw
                              • Hi Alex, the top, bottom and internal parts are 4.2mm grade 5 Ti, while the sides are all 8mm. The front forks are 9.7mm.
