Has anyone found out what the new mystery bot 'Hornet' is? I keep searching and coming up with nothing.
FRA UK Featherweight Championship 2014 hosted by RoboChallenge
Isn't it now killer bee or something?
Also, anyone know if we get entry for the Wednesday as well if we turn up early (because you booked the wrong bus) and can we still add teammates to our team sheets?
Edit:also, whether LiPos can be velcroed in and padded, if surrounded in at least 2.5mm thick steel and hardox? I'm very behind...
Binky's lipos are held down inside the robot with industrial velcro, its very hard to remove them, so I am sure it will be fine. We passed the tech-check with it last year.Originally posted by Flag Captured View PostEdit:also, whether LiPos can be velcroed in and padded, if surrounded in at least 2.5mm thick steel and hardox? I'm very behind...
And when that flipper looks like this:
You guys have fun
There are commercial available hydraulic heat exchangers, there are heat exchangers for petrochemical processes, and that's only the start of the list.
All perfectly rated for the pressures we work with, but non are suitable for our machines.
No, for something like this, it's custom work.
