Re: Gimson Robotics
Not sure what a 'gimpson' is (ahem!), but if you're talking about the GR01's it's not a straight comparison- operating data for Argos drill motors is not known and though they usually have the same motor can size they can sometimes be size '540' or '545' motors. Also you don't mention what voltage you would run at?
As a generalisation a single GR01 is very likely to be more powerful at a comparable voltage to a cheap drill, but double as 'powerful' as you suggest (1 GR01 vs. 2 cheap drills) I cannot know.
