Gimson Robotics
  • #61
    Re: Gimson Robotics
    Not sure what a 'gimpson' is (ahem!), but if you're talking about the GR01's it's not a straight comparison- operating data for Argos drill motors is not known and though they usually have the same motor can size they can sometimes be size '540' or '545' motors. Also you don't mention what voltage you would run at?
    As a generalisation a single GR01 is very likely to be more powerful at a comparable voltage to a cheap drill, but double as 'powerful' as you suggest (1 GR01 vs. 2 cheap drills) I cannot know.
    • #62
      Re: Gimson Robotics
      i think the only way to see the difference is by..................FIGHT!!!.....
      • #63
        Re: Gimson Robotics
        i've just ordered a pair of the 14.4v version of these motors can someone tell me the awg of the wire for these motors at 14.4v?
        • #64
          Re: Gimson Robotics
          You can buy with or without wire tails on the motor, if you decide to have them (plain or with Deans style connector) the ones provided are 2.5mm-sq cross section which is closest to 13AWG, as described on the product page.
          • #65
            Re: Gimson Robotics
            good spot, thank you
            • #66
              Re: Gimson Robotics
              i've just ordered
              Have you actually tried to place this yet btw, I've not had anything though the system yet - Apologies if this is a problem at our end
              • #67
                Re: Gimson Robotics
                no got them.....they are the bizz, thanks
                note: whats the total thread length of the brass insert (m5)? I have a 3mm aluminium base and was going to use M5x12mm length screws, is that the longest screw I could use with the motors.
                • #68
                  Re: Gimson Robotics
                  Ah good to hear, was a bit confused as the order was by a different name. The usable thread depth is 10mm in all front plate inserts, 5mm in rear mount inserts (by the motor) so you might want to cut the bolts down a little for the rear holes if you use them.
                  (From http://www.gimsonrobotics.co.uk/GR01_pl ... tions.html)
                  • #69
                    Re: Gimson Robotics
                    Mounting hubs suitable for the GR01 motor have been added to the website
                    • #70
                      Re: Gimson Robotics
                      Forgive me they look grea, can you give me an application
                      • #71
                        Re: Gimson Robotics
                        I've had a couple of customers want to mount objects to the motor without having to build their own adapter so came up with this. It's probably not too useful in fighting robot circles but you never know.
                        Also for anyone that's interested I've just spent a couple of hours reformatting the website to look as it should in Internet Explorer.. I have honestly not used IE in over a year before that, what a nightmare!
                        • #72
                          Re: Gimson Robotics
                          I think thats a good idea. ;-)
                          • #73
                            Re: Gimson Robotics
                            • #74
                              Re: Gimson Robotics
                              I love that you're familiar with memes, haha! I see them popping up all over the forums.
                              • #75
                                Re: Gimson Robotics
