The Crash & Burn Tournament
Here-a weeee goooo!
ArchAngel of the Abyss defeated Heart of Fire in devastating fashion before KOing Starstorm 2 but getting knocked in the pit anyway.
Clawdius Decimus Murderous dished out some pain on Gigabyte Evilution, and then advanced through Axe-O-Lotl, Dead Metal, and Matilda.
Roboteers, stand by...
The house robots are Sir Killalot and Shunt.
3...
2...
1...
ACTIVATE!!!
Its ArchAngel, getting up to speed, and ready to tear that uber crusher to thousands of pieces, but its Clawdius who gets in first and suffers a slight blow to the beak, but comes in again right away and clamps down onto the outer shell of ArchAngel! the lower spinning ring is still spinning, however, so Clawdius decides to dump it in the pit. He hits the pit release button, opening the pit, and, releasing the spinner from the claw, dumps it into the pit - NO!!! WHAT THE BLOODY HELL?!? ARCHANGEL IS FLUNG AWAY FROM THE PIT!!! What happened?! Instant replay please...okay, Clawdius dumping him in...and the lower spinning ring, still up to speed, touched the wall of the pit, sending it flying away! I say, ArchAngel was momentarily inside the pit, so the match should be Clawdius, but the judges disagree and allow the match to continue! What an amazing turn of events! And Archangel of the Abyss is allowed to fight this day! Were back to the action, Clawdius again trying to get under ArchAngel - look at this, the look on Steven McGregors face, it could kill!
But the look on Alex Holts face is a broad grin as he directs ArchAngel towards the flame pit. Clawdius still cant get under ArchAngel and now hes backing away as ArchAngel gets the spinning shell into play, spinning away! Oh, look, theres smoke around ArchAngel, so there was damage caused from the first blow by Clawdius! The question is, we dont know how much damage was cuased because ArchAngel is apparently spinning at full speed; Clawdius gets away, but ArchAngel follows him around the arena. Clawdius now decides at last to take a blow and backs into ArchAngel, and SMASH!!! Oh dear goodness me, the back wedge panel is completely gone! Clawdius turns around quickly and finds ArchAngel already halfway up to speed! Hurriedly he comes in but is tossed away a bit by the Most Feared (Vapour) Bot. He comes back in and ArchAngel is coming at him despite not at full speed again! Clawdius charges bravely and this time the crusher is hammered completely. ArchAngel stops, and is stuck on the wedge of Clawdius. Clawdius tries the crusher, but it is not functioning! Look at all the smoke, its pouring out of that hole that Clawdius made in ArchAngel at the beginning of the fight! And look at the front wedge of Clawdius, sheared by the lower spinning ring of ArchAngel, but ArchAngel now is about to be pitted by Clawdius - NO! ArchAngel escapes the pit again by rolling off the side of Clawdius! This fight has really taken its toll on our competitors - indeed it has as ArchAngel is not spinning at all, neither of the two spinning rings are mobile! Clawdius, on the other hand, has absolutely no weapon, and is only a wedge now, as he rams ArchAngel and barrels him into the wall. Sir Killalot fidgets a little as Clawdius backs away and rams ArchAngel against the wall again, very near the big Killalots CPZ. It seems that Clawdius is picking up where he once left off and scoops ArchAngel onto his wedge, and again heads for the pit. But Refbot is in the way! Sir Killalot has had enough, it seems, and treads carefully over by Refbot to avoid the pit. Shunt shoots out at the same time, and Clawdius really wants to get away. The Refbot holds up the yellow card. Ooh, boys youd better get back to your CPZs! And now that Refbot has moved backwards, Clawdius can - ah, no, tricky ArchAngel has snuck away again! Irritation is running high in Team Bravehearts control booth as Clawdius chases down ArchAngel and scoops him onto the wedge again!
10...9...
Clawdius turns, with ArchAngel, and goes a little too fast. The result is that both Clawdius and ArchAngel fall into the pit. But since ArchAngel fell in the pit first...
CEASE!
The unholy terror ArchAngel of the Abyss has finally been put to the sword.
CLAWDIUS DECIMUS MURDEROUS ADVANCES TO THE SERIES FINALS!!!!!!!
Heat E
Bloody Tears 2 VS. Aneurysm
Obliteration VS. The Ultimate Wedge
Tails VS. Dante
Biohazard VS. Megabyte
Tactics? Predictions? A pint of lager?
Here-a weeee goooo!
3...
2...
1...
ACTIVATE!!!
But the look on Alex Holts face is a broad grin as he directs ArchAngel towards the flame pit. Clawdius still cant get under ArchAngel and now hes backing away as ArchAngel gets the spinning shell into play, spinning away! Oh, look, theres smoke around ArchAngel, so there was damage caused from the first blow by Clawdius! The question is, we dont know how much damage was cuased because ArchAngel is apparently spinning at full speed; Clawdius gets away, but ArchAngel follows him around the arena. Clawdius now decides at last to take a blow and backs into ArchAngel, and SMASH!!! Oh dear goodness me, the back wedge panel is completely gone! Clawdius turns around quickly and finds ArchAngel already halfway up to speed! Hurriedly he comes in but is tossed away a bit by the Most Feared (Vapour) Bot. He comes back in and ArchAngel is coming at him despite not at full speed again! Clawdius charges bravely and this time the crusher is hammered completely. ArchAngel stops, and is stuck on the wedge of Clawdius. Clawdius tries the crusher, but it is not functioning! Look at all the smoke, its pouring out of that hole that Clawdius made in ArchAngel at the beginning of the fight! And look at the front wedge of Clawdius, sheared by the lower spinning ring of ArchAngel, but ArchAngel now is about to be pitted by Clawdius - NO! ArchAngel escapes the pit again by rolling off the side of Clawdius! This fight has really taken its toll on our competitors - indeed it has as ArchAngel is not spinning at all, neither of the two spinning rings are mobile! Clawdius, on the other hand, has absolutely no weapon, and is only a wedge now, as he rams ArchAngel and barrels him into the wall. Sir Killalot fidgets a little as Clawdius backs away and rams ArchAngel against the wall again, very near the big Killalots CPZ. It seems that Clawdius is picking up where he once left off and scoops ArchAngel onto his wedge, and again heads for the pit. But Refbot is in the way! Sir Killalot has had enough, it seems, and treads carefully over by Refbot to avoid the pit. Shunt shoots out at the same time, and Clawdius really wants to get away. The Refbot holds up the yellow card. Ooh, boys youd better get back to your CPZs! And now that Refbot has moved backwards, Clawdius can - ah, no, tricky ArchAngel has snuck away again! Irritation is running high in Team Bravehearts control booth as Clawdius chases down ArchAngel and scoops him onto the wedge again! 10...9...
CEASE!
Heat E
Tails VS. Dante
