The Crash & Burn Tournament
Yes, I do.
shazamshazam@hotmail.com
Yes, I do.
. Knightrous Wedge rights himself ala T-Minus, with a 540 degree flip that awes the crowd, and is backed into by Toby. Back skirt meets side skirt, and they are stopped again. Knightrous Wedge wheels himself towards Tobys side, hoping to get a shot, but Toby keeps reversing. Aaron, however, wants to see a flying robot show and chases right after him. Toby stops€¦and Aaron has once again fallen for the power dive trick€¦no! Knightrous Wedge has stopped right in front of Toby. It looks like a real Mexican stand-off€¦only we aint got no Mexicans
. Neither are moving. Refbot comes over and slightly nudges Knightrous Wedge, who turns to drive him off. Bingo! Toby rams into Knightrous Wedge, and this time the reverse happens: Toby flies right on top of Knightrous Wedge, but onto the side. Aaron, in his delight, hits the flipper button too soon: the flipper hits Toby and gently nudges him over. This, however, has saved Knightrous Wedge from flipping itself, and as Toby rolls over, Knightrous Wedge catches him before the skirts hit the floor. Fasten your seatbelts, gents!
Whoosh! With the flick of a button, the flipper of Knightrous Wedge activates again, with Toby on top. The 120 degree angle of the flipper means that not only has Toby been flung high into the air, but over top of Knightrous Wedge as well! He lands just inside of the arena, but the rollbars look very bent after that landing, and Toby just makes it onto his wheels, only to be rammed again by Knightrous Wedge, who turned around just in time. Skirt meets skirt again, and again the two stop completely; Knightrous Wedge reverses and goes for the rammer again, but finds that he is gone. Then he sees that Toby has rammed into the pit release, opening the dreaded pit! Aaron laughs in the control booth, figuring that that is a cheap way to win, and so Knightrous Wedge advances on Toby - WATCH OUT! Knightrous Wedge has again run over the plough of Toby, and nearly threw himself into the pit! Toby rushes forward, eager to punt the Australian bot into the pit, but Knightrous Wedge reverses away€¦
with its T-Minus shape and high-powered flipper. It also has 5mm titanium, whether it is grade 5 remains to be seen. However, semi-exposed wheels may be a problem.
.Nowletusgetonwiththefights.
Aquarius rights himself€¦right into Cassius Chrome! Not good for Tony, as Cassius Chrome shoves Aquarius into the side wall, and up onto his rear. Kali drives right into Cassius Chromes rear and begins lifting. The house robot is suddenly finding himself in a difficult situation, with only his plow on the ground, and his head to the wall. Against the wall and underneath Cassius Chrome, but not out, Aquarius fires the flipper, and pushes himself into Cassius Chrome. Cassius Chrome is shoved back into Kali, who again lifts the house robot. Aquarius backs into Kali, and fires the flipper. Cassius Chrome is tipped€¦and out! You saw it here! Cassius Chrome: over the fence and out of the arena! Refbot does not look too pleased. Time is running out, as Aquarius shoves himself backwards into Kali, who has the lifting up and so cant use it on Aquarius. Kali reverses, trying to separate Aquarius from her, but Aquarius keeps backing into her, and eventually€¦POW! Kali is shoved into the wall, and Aquarius scuttles away again. Oh dear! Kalis lifting arm is stuck! After that collision, no wonder!
